elcableguy77
Firing Up The APU In FS9
Thu May 29, 2008 5:08 pm
Well, I went searching the forum and found nothing, so maybe I could get some help from my fellow flight simmers.
It seems that whenever I start a flight at the gate with my engines off, power lasts for maybe 10 minutes before everything goes dark. I know this is a simulation of the backup battery. But, is there a way to crank the APU so I can have power on the ground? I use mostly freeware, with the payware being the SMS Boeing and Airbus packs, so none of them have an apu power switch (that I'm aware of).
Any help would be greatly appreciated.
(edited for spelling)
[Edited 2008-05-29 10:09:29]
Former ZW F/A | "Wisconsin 72A, contact departure, see ya."
jamesbuk
RE: Firing Up The APU In FS9
Thu May 29, 2008 5:40 pm
They dont have APU simulated. So no there isnt a way to fire it up. The best way with the SMS is to use the battery which will last you about 5-7 mins. That should be enough time to get the autopilot and GPS programmed  silly
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
jamesbaldwyn
Thu May 29, 2008 5:47 pm
Do it the lazy mans way CTRL + E  Silly
ACDC8
Thu May 29, 2008 7:23 pm
Odd, if I shut my engines off in FS9, I could leave the computer running for the rest of the day and when I come back, everything still has power.
A Grumpy German Is A Sauerkraut
LIA310
Fri May 30, 2008 1:26 am
Quoting ACDC8 (Reply 3):
what plane is it ?
ACDC8
Fri May 30, 2008 5:49 am
Quoting LIA310 (Reply 4):
what plane is it ?
Pretty well every plane I've used from the default to various add-ons. Maybe my FS9 is a special edition ...  Silly
OlegShv
Wed Jun 04, 2008 8:58 pm
Quoting ACDC8 (Reply 5):
Well, I suppose you have checked (or unchecked) one of realism options that deals with discharging the batteries.
ACDC8
Fri Jun 06, 2008 8:48 am
Quoting OlegShv (Reply 6):
I usually just leave everything as defualt, so that could explain it. Didn't even think about that .... lol!
CanadianNorth
Thu Aug 21, 2008 6:14 pm
Quoting Elcableguy77 (Thread starter):
Hmm. According to CARs the battery has to supply at least 30 minutes of power once you loose the engines. Perhaps you have lots of non-essential systems running though.
Anyhow, to answer yer question as far as I know the APU does not exist in the FS9 world.
CanadianNorth
HS-748, just like a 747 but better!
ClearedDirect
Thu Aug 21, 2008 8:10 pm
Quoting CanadianNorth (Reply 8):
not on most freeware - there are plenty of payware a/c have functional apu's in FS9.
Also there is a option within FSUIPC (pay version) that stops battery discharge.
