MaverickM11
How To Maximize FS9 AI Frame Rate?
Mon Jun 02, 2008 10:56 pm
Any ideas how to maximize frame rates with full 100% AI at all airports? Can I adjust the weather/scenery density or maybe screen resolution to maximize the frame rate? I've tried limiting the weather and scenery complexity and density but I was hoping there were some other tricks.
E pur si muove -Galileo
B727-200
RE: How To Maximize FS9 AI Frame Rate?
Tue Jun 03, 2008 4:13 am
What are your system specs? I am running 100% everything on FS9 (including over 120,000 AI flight plans and loads of addon scenery) and sit on 40+fps all the time. I am using a quad-core machine with 4GB RAM and nVidia 8800GTS.
B727-200.
UA772IAD
Tue Jun 03, 2008 6:46 am
Limit your drawing distances (distance visibility at the lowest mileage/cloud formations at the lowest mileage), this helps a lot. You don't need to see clouds or scenery that is 300 miles away...
MaverickM11
Wed Jun 04, 2008 6:28 pm
Quoting B727-200 (Reply 1):
That's an excellent question. Off the top of my head I can tell you it's a 2002 Dell...I'll have to look up the rest when I'm home.
Delboy
Thu Jun 05, 2008 12:02 pm
Maverick
All of the things you mentioned will help to increase your framerate. Just remember that FS9 only uses one core of a CPU, it don't matter if you have dual or quad but if you have they might help by taking off workload for other aspects of the PC.
Personally, I don't use 100% AI, you can be sitting for up to 45mins at Heathrow waiting to take off at busy times, I like to fly!
Hope you find the ultimate solution, don't forget to let us know what is was when you do.
AA388
Wed Jul 23, 2008 11:12 pm
i have a single core processor and i have trouble with frame rates even tho i have a decent video card and 4gb of ram.
-max
Flown on A319, A320, A321, A330-200, A340-300,600, 717, 737-3,5,7,8,9, 747-400, 757-2, 767-300, 777-200
Delboy
Thu Jul 24, 2008 9:02 am
I may be wrong but I don't think FS9 makes use of 4Gb of RAM anyway. I think the max is 3Gb but I'm sure someone will tell me thats rubbish!
EA CO AS
Thu Jul 24, 2008 9:26 am
Quoting MaverickM11 (Thread starter):
Yeah - don't put it to 100%. Try around 70% or so; you'll like what you see from a framerate perspective, and the eye-candy factor won't be tarnished either.
