AA388
Is This A Good Computer For FS9?
Fri Aug 29, 2008 2:31 am
And also should i switch to FSX?
Intel core 2 quad processor Q660 2.4 GHz 1066MHz 8
Msi P31 Neo-F Intel motherboard
2 Buffalo DDR2 800MHz Memory
MSI Geforce 8500GT 512MB PCI-E
320GB Seagate S-ATAII 16MB hardrive
let me know what you think of this system.
-max
Flown on A319, A320, A321, A330-200, A340-300,600, 717, 737-3,5,7,8,9, 747-400, 757-2, 767-300, 777-200
Burkhard
RE: Is This A Good Computer For FS9?
Fri Aug 29, 2008 11:38 am
Yes and no.
FS9 only can use one core. So while a second core may help from time to time for auxiliary processes, the two last cores will be sleeping. So basically is is a 2.4 GHz CPU for FS9 with three idles spectators.
The 8500GT is not really intended for 3D games, it is intended for watching movies. FS9 uses the GPU less than FSX does, but the 8500 is really low end graphics. Prefer a 8600GT for FS9.
And while the quad is very fine for FSX, a 8500 and even a 8600 just cannot render the details of FSX - either take a 8800GTS or above or keep the fingers from FSX.
This said, FSX is the much better Flight Simulator, and I claim even the faster one - if you compare apples with apples. The level of detail you get in FSX is often 4 or 8 times the one in FS9 at same slider setting - as example autogen in FS9 at very dense is as much as in FSX with sparse. With the above CPU and a GF8800GT FSX should run very smooth.
But then it comes to how much you have invested into addons that are not FSX - compatible.
yooyoo
Fri Aug 29, 2008 7:05 pm
AA388,
I don't want to highjack your thread but at the same time i was hoping to get some feedback on my new computer without starting another thread. I hope this is ok?
Running FSX
Intel® Core™2 Q6600 Quad-Core (8MB L2 cache,2.4GHz,1066FSB),
Memory 4GB Dual Channel DDR2 SDRAM at 800MHz- 4DIMMs
Video Card 256MB Radeon ATI HD 2600 XT
Hard Drive 250GB Serial ATA Hard Drive (7200RPM) w/DataBurst Cache
Quoting AA388 (Thread starter):
I was running FS9 at slightly lower than max setting on a computer almost half that power if that helps.
I am so smart, i am so smart... S-M-R-T... i mean S-M-A-R-T
csturdiv
Fri Aug 29, 2008 10:36 pm
Quoting YooYoo (Reply 2):
I would upgrade that video card, especially with FSX. You have a coupe of a computer with an economy video card. I've only used the FSX beta and even with my old Nvidia 6800 (I think that was it) 256MB it ran sluggish. Be careful when you upgrade, the newer video cards are double wide now, meaning they need two slots in the case. I bought a Nvidia 768MB 8600 GTX card about a year and a half ago, only to find that it would not fit in my case because it was double wide and was hitting the CPU heatsink when I tried to install it. So it is now sitting on my bookshelf waiting for a new computer (if I ever build one).
An American expat from the ORD area living and working in SYD
AA388
Fri Aug 29, 2008 10:55 pm
Quoting Csturdiv (Reply 3):
Is my graphics card ok or is that my weak point?
-max
navymmw
Sat Aug 30, 2008 5:25 am
does this seem like a good setup for FSX?
Intel Core 2 quad Q6600 (2.4GHz)
5GB of RAM
and a 8800GS
yooyoo
Sat Aug 30, 2008 12:43 pm
Quoting AA388 (Reply 4):
my other computer had an integrated card and i'm sure your card is far superior. 512 mb of memory is a definite plus. Try Googling your card along with Flight Sim 9 , you may get some people commenting on it.  twocents
AA388
Sat Aug 30, 2008 1:59 pm
i got my computer and its fast but i have blurries on the ground and buildings. Can you guys give me a souloution?
-max
jetmatt777
Crew
Sat Aug 30, 2008 9:49 pm
Try turning your scenery details up a bit. If not, add more RAM.
Also, I am thinking of buying a new PC. How does this one look?:
AMD 2.6 GHz dual core processor
4 GB RAM
nVIDIA GeForce 8200 motherboard GPU + GeForce 6200 256 MB PCI GPU (run 1 monitor on 1 graphics card, and another monitor on the other.
Click Here to see it
How would I do in FS9, sliders maxed, on a short final for the average payware airport, or advanced freeware?
Also, how would I do in FSX in the same scenerio/settings named above?
Currently I have a slow PC, 3-7 FPS on final for your average default airport with sliders on medium low.
I hate to hijack your thread, but no point in having 3 or 4 of these threads open at the same time, all asking the same questions.
-Matt
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
AA388
Sun Aug 31, 2008 6:29 am
i have no problem for people asking about their computers in this thread.. And do i really need more than 4gb of ram on windows xp?
-max
csturdiv
Sun Aug 31, 2008 4:38 pm
Quoting AA388 (Reply 9):
The 32bit version of XP only supports 4GB of RAM, so adding more RAM would not do anything. You would need a 64bit OS to take advantage of more RAM.
I sometimes have blurries on the ground also, and most of them go away after a while. I do not have a newer PC, but it isn't that bad either....3Ghz PentiumD, 3GB RAM, 512MB GeForce 7600, XP SP3. You can try tweaking your FS9.CFG file. I have mine tweaked and it helps. Do a Google search of fs9.cfg tweaks and read some of the results and try the tweaks. To be safe, make a backup copy of your old FS9,CFG file in case you want to go back.
I need to buy a new video card, my current card's fan is starting to squeak . I am not sure if I will ever buy an EVGA card again, this card has already been RMA'ed once to them for fan issues.
navymmw
Tue Sep 02, 2008 2:05 am
Im getting the 8800GT in the mail soon. Im looking foward to it.
I currently have a Core 2 quad Q6600 2.4GHz
5GB of RAM
Intel Grpahics Media accelerator 3100
and Windows vista (64-bit)
I will be getting rid of the Intel Grpahics(Integrated graphics BLAH!) and swapping it with my awsome new 8800GT.
So how much of a difference should I see in both visual and performance in FS9?
AA388
Tue Sep 02, 2008 2:36 am
Does anyone else have anything to say about the blurries? and with regards to changing my fs9.cfg i cannot find it and i have searched high and low.
-max
csturdiv
Tue Sep 02, 2008 4:24 pm
It is hidden on your hard drive. Do a search for FS9.CFG and make sure that you turn on the option to search in hidden folders. The tweaks do help some, so it is worth looking into. But there is no magic fix for blurries, I see them still, but after a few seconds they turn crisp. Later this week I should be getting my new 8800GT card from Newegg and hopefully I'll see a difference.
767nutter
Sun Sep 07, 2008 4:17 pm
This is the basic specs of my ''old'' pc for which i use FS9:
AMD Athlon(tm) 64 processor
3000+
2.00 GHz, 1.00 GB RAM
PAE
and i still get about 20-35 FPS with PMDG's,Level-D's , Justflight's etc add-ons with Add-on scenery set at High
I'm building a new pc for FSX at the moment, and am going to put a quad core processor in, with a good graphics card ( cant remember name off top of my head) with 4GB ram, so hopefully get good results with that
Ps76
Sun Sep 07, 2008 5:15 pm
Hi,
For the Blurries I found this a long time ago from a user JimmiG who always used to have really nice screenshots (from Megascenery). I think I've only made the first 6 values for mine but it worked a bit I think (at least on my system). Of course I'm assuming you tried the display settings (max texture size, terrain detail etc. I think) and of course I advise please back up the Fs9.cfg before making any changes in case it messes things up or you don't like the results.
The "tweak" was pretty much:
"Find and change these values in fs9.cfg (after making a backup of the original)
For loading shaper textures farther out etc.
TERRAIN_DEFAULT_RADIUS=9.900000
TERRAIN_EXTENDED_LEVELS=3.5
TERRAIN_EXTENDED_RADIUS=9.900000
TERRAIN_ERROR_FACTOR=100.000000
TERRAIN_MIN_DEM_AREA=30.000000
TERRAIN_MAX_DEM_AREA=100.000000
TERRAIN_MAX_VERTEX_LEVEL=20 //<---19 = 80m mesh, 20 = 38m mesh, 21 = 19m mesh. So for Norcal, 20 is best.
TEXTURE_BANDWIDTH_MULT=400 //<---Supposed to load up textures faster
Also, using 30 miles visiblility in FS. Extended Terrain Textures disabled. Using 8x Anisotropic Filtering and 4x AA. Running an Athlon64 3500+ with a Radeon X800XT but I got similar quality (but lower frames and slower texture loads) with my old Athlon 2400+ and 9700 Pro. "
Hope it might help a little (blurries are the pits but it sounds like your system should fly - I have a Sempron2300+ here I think!).
Rgds,
Pierre.
AA388
Tue Sep 09, 2008 10:33 am
ive noticed the blurries less and less and it helps when i use add-on scenery so if you guys can tell me any good ones that would help.
-max
regupilot
Mon Sep 15, 2008 3:10 am
Hey all!
Got late to the thread, but some tips.
The FS9.CFG file is located inside your profile folder:
c:Documents and SettingsApplication DataMicrosoftFS9FS9.CFG
Where C: is the drive where Windows is installed, and is the name of your profile name.
For RAM: Windows XP 32bit version cannot address more than 4GB on paper, and even with 4GB installed, it won't see it, since there are other components "stealing" away the communication lanes for that extra bit of RAM, so your system will read 3.something GB of RAM or so.
As for the graphics, as I have mentioned before in older threads, RAM is not the single most important component, first pick a good Graphics processor, or GPU. Then pay for the highest amount of RAM you can afford with that good GPU. For Nvidia GPUs, try anything higher than a x600 and up, ie: 7600, 8600, 8600 or up, 7800, 8800, 9800. If you see a number below 6 on the product name, like a 8500, your game will not be as pleasant, graphics wise since those cards are not designed for graphic intense gaming.
With ATI, the story gets a bit more complicate. It used to be the same as with nVidia... nothing containing a number lower than 6: 9600, X600, X1600, 2600XT and 3600. But with the newer Radeon 4850, things get switched a bit... even the 2600XT and 3650 was lazy at gaming, but a good Radeon 4850 will do the trick pretty good.
If you have an Intel card, RUN (don't walk) and get a decent ATI or nVidia card! You don't know what you're missing.
I would replace that video card with a nice 8800GT (G92) or a 9800. The 9800GX2 is currently the best performer single card for FSX... only that it's somewhat expensive.
The 2600XT is great for FS9, but for FSX... meh. Blame MS for that, but even the newest GeForce 280 can't bring up frame rates above 30 with max settings. I would move up to a Radeon 4850 or a GeForce 9600
Quoting Jetmatt777 (Reply 8):
4 GB RAM
That machine looks more like a HTPC - Home Theater PC. I wouldn't recommend for gameplay. Also, as far as I know, Windows does not work with 2 video cards at the same time. Multi-monitor support is achieved with a single card that has 2 VGA or DVI display ports. For running FlightSim, for example and Squawk Box, ServInfo in one machine, you need more than a 8200 or 6200 card. You need no less than a GeForce 7600 for it to run decent.
Windows is happy with even 512MB of RAM. The rest of the memory is for your aplications. The more stuff you run in your PC at the same time (AntiVirus, Winamp, Last.fm, Limewire, etc) the more memory you need. That said, you DON'T NEED 4GB for Windows, and if your Windows version is 32bit, FS9 or FSX will not take full advantage of those 4GB.
Now, for the textures... make sure the global terrain textures is set to max. If it still blurs, maybe is not your PC but the actual scenery.
Also, a great way to speed up FlightSim is by using RAID 0 and or RAID 1 in your machine. That gave me more than 25% increase in performance... really worth it.
Hope this helps.
jetmatt777
Crew
Mon Sep 15, 2008 9:58 pm
Quoting ReguPilot (Reply 17):
Little Late :P Just got:
Gateway
AMD 2.1 GHz tri-core proc.
4GB RAM
ATI RADEON 3200 motherboard graphics. Gonna put my nVIDIA 6200 in sometime soon.
regupilot
Tue Sep 16, 2008 5:38 am
Quoting Jetmatt777 (Reply 18):
Please report how it performs! Thanks! Big grin
AA388
Wed Sep 17, 2008 12:32 am
what is raid??
-max
jetmatt777
Crew
Wed Sep 17, 2008 3:40 am
Quoting ReguPilot (Reply 19):
Well, with Fly Tampa's freeware KBOS scenery I get 30 FPS with some Delta VA planes, but since I "upgraded" from my 2003 Cathode Ray Tube Monitor (CRT) to a 22" WestingHouse 1680 x 1200 LCD monitor, I get 10-15FPS, so didn't know monitor would have anything to do with FPS, but I guess it's the increased resolution. It has enough RAM where I can run Photoshop and FS9 at the same time without any significant loss in performance, running Vista 64 bit. And we all know both use a significant portion of processing power and system memory (RAM).
regupilot
Wed Sep 17, 2008 11:34 pm
Quoting AA388 (Reply 20):
what is raid??
Redundant Array of Independent Discs. To keep the explanation under the scope of this threa, RAID speeds up your FlightSim experience by a whole lot. You will need to have 2 or more Hard Drives, preferably of the Serial ATA bus since they are cheaper than SCSI drives. IDE drives (the ones that use the big ribbon cable) are not supported in the latest simple RAID configurations, but that doesn't mean they cannot be used.
So what you do is for example, take two 160GB SATA Hard Drives, set them to RAID 0, and you're good to go. Again, there are a lot more details behind RAID, but that's a nice, and quick explanation.
Quoting Jetmatt777 (Reply 21):
Here's the deal, there is a reason why (as I have said many many times) there is a GeForce 8500, a 8600 and 8800. They're not created equal, and they're not priced equal. If a GeForce 6200 or 8500 were to do the same as the 8800, why would we need an 8800 for?
Your problem lies in that, it is very likely that the maximum resolution of your CRT was 1280X1024. That is a very "easy" to handle resolution for any low end GPU. If you play FS in window mode, then you'll be forcing the GPU to work with your current monitor's resolution, which is too much to handle for the GPU. Here RAM doesn't matter or processing speeds, this is a 90% GOP thing. You could have had nice frame rates with your nicely FlyTampa Scenery, I'm sure that without custom AI traffic and with the Settings slider set way back to the left. Same with your new monitor... 15FPS, but sliders to the left and no custom traffic.
I did a quick (well, not that quick) search for screen shots in this very forum, to show you the difference of what a nice Graphics card can do with nice frame rates. A GeForce 8600 or equivalent is capable of more or less do something like this:
http://www.fsimages.net/watermark2.php?imgsrc=img1/11781937271.jpg
Then check this shot and compare... this is what a low end GPU is capable of doing at its best.
http://www.airliners.net/uf/536883234/11911873170O10Rk.jpg
A good GPU makes the difference between this game play:
And this:
jetmatt777
Crew
Thu Sep 18, 2008 10:22 pm
Actually, I was running Very High Scenery settings, and very low AI traffic, and got 30ish FPS with my 1024*768 monitor, but after getting the 1680 * 1050 it jumped down to 15ish and studders alot. I'm not really looking to spend a fortune on a new GPU.
Users browsing this forum: Google [Bot] and 1 guest
