kimberlyRJ
Your Last FS Flight Questionnaire - Info Needed
Tue Oct 21, 2008 8:53 pm
Hi all
Sorry for all the questions but I am writing an article for Avsim and need to know this information for some statistics and flight information (from someone else but myself). If you can fill in the template below - thanks guys...
You can find a blank template at the bottom of this post...
Date of last FS flight: 21/Oct/08
FS8/FS9/FSX: FSX
Aircraft: MD11 (PMDG)
Airline: British Airways (fictional)
Livery: Landor (DC10 style)
Is this a real scheduled flight:
Flight number :
To: TBPB (Bridgetown, Barbados)
Published Departure Time: 12:45z
Published Flight Time: 8:35
Published Arrival Time: 21:20z
Actual Departure Time: 12:42z
Actual Flight Time: 8:00
Actual Arrival Time: 20:42z
Pre-Flight Procedure: plan route, enter on FS Build, import into Active Sky X, analyze data (wind speeds), load aircraft (weights, pax, fuel needed) & program the FMC on the MD11.
Programs to be used on pre flight / during flight:
CRZ Speed: m.82
CRZ Altitude/s: FL340>FL360
SID: SAM2M
Route: sam-gibso-dawly-lnd-gapli-gunso-4620n-4227n-frs-3735n-3439n-3241n-2845n-
2548n-2152n-1854n-1458n-aloki
Were did you get this route from:
Is this a real world route:
STAR:n/a
Weather: en route notes: weather at EGKK clear, westerly wind at 4kts. Average winds aloft are at 261at31kts. Thunder cells reports at FL220 thru FL390 around the Azores. Weather in TBPB thunder cells in the vicinity, cloud base at 2500ft, top at 5,000ft – scattered. Wind easterly at 2kts.
PAX: 322
LAPS: +6
Flight Deck Crew: 2
Cabin Crew: 12
Total Souls on board: 342
Take Off notes: normal ops
Climb notes: normal ops
CRZ notes: normal ops
Decent notes: normal ops
Landing notes: crew to be seated early due to expected turbulence on approach.
Daylight Hours Logged: 8.2
Night time Hours Logged: 0.0
IFR Hours Logged: 8.0
VFR Hours Logged: 0.2
Thanks for your help guys - Below my name you will find a template to enter your information on. Please highlite the template and click 'quote selected text'
Kimberly.
FS8/FS9/FSX:
Aircraft:
Airline:
Livery:
To:
Flight number :
Actual Flight Time:
CRZ Speed:
CRZ Altitude/s:
SID:
Route:
STAR:
Weather en route notes:
PAX:
LAPS:
Flight Deck Crew:
Cabin Crew:
Take Off notes:
Climb notes:
CRZ notes:
Decent notes:
Landing notes:
IFR Hours Logged:
VFR Hours Logged:
zappbrannigan
RE: Your Last FS Flight Questionnaire - Info Neede
Sat Oct 25, 2008 7:02 am
Well nobody else has given you anything, so here's my last one:
Date of last FS flight: 25 Oct 08
FS8/FS9/FSX: FSX
Aircraft: PMDG MD-11 Cargo
Airline: FedEx
Livery: FedEx
To: YMHB (Hobart)
Is this a real scheduled flight: Not with FedEx
Flight number :
Actual Departure Time: 06:05z
Actual Flight Time: 00:56
Actual Arrival Time: 07:10z
Pre-Flight Procedure: Get terminal and enroute weather from Airservices Aust., extract route from Enroute/FPR section of airways manual, check route on low/high alt enroute charts, plan applicable departure procedures, load and check aircraft, check departure performance data, then load FSX and pre-flight aircraft as per published procedures
Programs to be used on pre flight / during flight: FSBuild (for converting flight plan to PMDG format)
CRZ Speed: .829M
CRZ Altitude/s: FL370
SID: COWES FIVE
Route: YMML DCT ML H169 CLARK W519 HB DCT YMHB
Where did you get this route from: Jeppesen Airway Manual (Enroute - Flight Planning Requirements AU)
Is this a real world route: Yes
STAR: N/A (Hobart Rwy 30 VOR approach from HB transition)
Weather en route notes: YMML 340/15-25 CAVOK, YMHB 340/12G22 CAVOK
Enroute winds: FL340 wind 258/49, FL385 wind 255/70
PAX: Nil
LAPS: Nil
Flight Deck Crew: 2
Cabin Crew: Nil
Total Souls on board: 2
Take Off notes: Dep YMML Rwy 34 via COWES FIVE
Climb notes: Nil
CRZ notes: Nil
Descent notes: Nil
Landing notes: Arr YMHB Rwy 30 via Rwy 30 VOR
Daylight Hours Logged: 1.1
Night time Hours Logged: Nil
IFR Hours Logged: 1.1
VFR Hours Logged: Nil
BAW076
RE: Your Last FS Flight Questionnaire - Info Needed
Fri Oct 31, 2008 2:30 am
Date of last FS flight: Thursday 30 October 2008
FS8/FS9/FSX: Flight Simulator 2004 (FS9)
Aircraft: Airbus A320-200
Airline: bmi British Midland
Livery: Current livery
To: London Heathrow (EGLL)
Is this a real scheduled flight: Yes
Flight number : BD093 (Callsign "Midland Six X-Ray Foxtrot")
Published Departure Time: 1935 GMT
Published Flight Time: 1h 35m
Published Arrival Time: 2110 GMT
Actual Departure Time: 2327 GMT
Actual Flight Time: 0h 55m
Actual Arrival Time: 0022 GMT (Fri)
CRZ Speed: 465kts Ground Speed - Mach 0.78
CRZ Altitude/s: FL300
SID: n/a
Route: EGAC DCT IOM MCT HON BNN4A.BNN EGLL
Were did you get this route from: Routefinder
Is this a real world route: I believe so
STAR: BNN4A
Weather en route notes: EGAC clear Wind 233 at 5, smooth throughout flight, cloudy EGLL Wind 054 at 9.
N754AN (x2), G-CPEL, G-MIDE, G-BPEC, G-BZHC, EI-DCH, LN-KKN, G-VIIW, G-BNLT, G-DBCA, G-MEDE, G-DBCE, G-MIDP.
UA772IAD
Fri Oct 31, 2008 10:02 am
Date of last FS flight: 26 October, 2008
FS8/FS9/FSX: FS9
Aircraft: B747-400 (PMDG)
Airline: United
Livery: Old C/S, N187UA
To: Washington/Dulles (IAD)
Is this a real scheduled flight: YES
Flight number : UA917
Published Departure Time: 12:20 local
Published Flight Time: 8H 41M
Published Arrival Time: 15:50 local
Actual Departure Time: 12:39 local
Actual Flight Time: 8H 53M
Actual Arrival Time: 16:00 local
Pre-Flight Procedure: Load weather, load FS Passengers, Load FS2Crew, Load RCv4, start preflight flow via FS2Crew
Programs to be used on pre flight / during flight: FlyingTigers Group (VA) ACARS, FSPassengers, Activesky, Radar Contact v4
CRZ Speed: M 0.84-.85
CRZ Altitude/s: FL340, FL380, FL400
SID:
Route: (Stored on other computer)
Were did you get this route from: Flightaware
STAR:
PAX: 347
LAPS:
Flight Deck Crew: 3
Cabin Crew: 15
Total Souls on board: 365
Take Off notes: Runway 25L
Climb notes:
CRZ notes: 100+ kt headwinds all the way across the Atlantic
Decent notes:
Landing notes: Runway 1R
Daylight Hours Logged: 8.8
IFR Hours Logged: 8.8
VFR Hours Logged: 0
DiamondFlyer
Fri Oct 31, 2008 7:52 pm
Date of last FS flight: 10/28/2008
FS8/FS9/FSX: FSX
Aircraft: Project Opensky 757-200W
Airline: Delta Airlines
Livery: Delta NNC2007
To: KMCO
Flight number : DAL973
Published Departure Time: 15:35
Published Flight Time: 01:33
Published Arrival Time: 17:08
Actual Departure Time: 15:40
Actual Flight Time: 01:24
Actual Arrival Time: 17:04
Pre-Flight Procedure: Delta VA preflight
CRZ Speed: Mach .78
SID: BRAVS5
Route: ATL BRAVS5.WALET OTK.PIGLT1
Were did you get this route from: flightaware.com
Is this a real world route:Yes
STAR:PIGLT1
PAX:
LAPS:
Flight Deck Crew:
Cabin Crew:
Take Off notes:
Climb notes:
CRZ notes:
Decent notes:
Landing notes:
Daylight Hours Logged: 1.4
IFR Hours Logged: 1.4
VFR Hours Logged:
From my cold, dead hands
usair320
Mon Nov 17, 2008 10:58 pm
Date of last FS flight: 11/17/2008
FS8/FS9/FSX:FS9
Aircraft: IFDG A319-132
Airline: US Airways
Livery: US NC N809AW
To: KPHX
Flight number : AWE015
Published Departure Time: 14:00
Published Flight Time: 00:51
Published Arrival Time: 14:51
Actual Departure Time: 14:00
Actual Flight Time: 00:45
Actual Arrival Time: 14:41
CRZ Speed: 304
Route: CHILY1 IGM TYSSN2
Weather en route notes: Wind 150 at 11 for arrival in PHX
PAX:109
LAPS:0
Flight Deck Crew:2
Cabin Crew:3
Total Souls on board:114
Take Off notes:
Climb notes:
CRZ notes:
Decent notes:
Landing notes:
Daylight Hours Logged: .4
IFR Hours Logged: .4
VFR Hours Logged:
Other: FSpax report.(Note: Not official report as I can't access it)
Pax opinion: 100%
Liked drink service and music on the ground.
Landing -294 (Nice)
Perfect +160
Problems(pilot notes, not fspax): While lining up for landing on 26 ATC directed an MD-80 to land. Seperation seemed to be no more than 100 ft. I took action by throttling up setting 15 degrees of flap and performing a right 360 to land.
UltimateDelta
Tue Nov 18, 2008 12:33 am
Aircraft: Boeing 777-312ER
Airline: Singapore Airlines
To: Hong Kong- Chek Lap Kok Int'l
Real world flight: Don't know
Flight number: SQ4517
Departure time (Scheduled): 11:22 AM
Actual: 11:27 AM
Flight time: 1:54
Arrival time: 13:21 PM
Preflight procedure: don't remember
Programs used during flight: don't remember
CRZ Speed: 473 kts
CRZ altitude: FL340
Route: VFR Direct GPS RCTP-VHHH
Where did this route come from?: My imagination
Real world route?: Assume so
Weather en route: Wind at 253 entire flight
Pax: 317
Flight crew: 2
F/As: 12
Total: 331
T/O notes:
Climb notes:
CRZ notes:
Descent notes: a little fast, about 2200 fpm
Landing notes: Runway 25L, touchdown at 169 kts
Daytime hours logged: 1.9
Night: 0
VFR: 1.9
IFR: 0
Slight loss of separation on finals to 25R because a 747 was departing from that runway approximately 1 minute from t/d of my aircraft. Aircraft cleared runway as mine crossed the threshold.
Sorry I couldn't provide all the information- I flew this one two days ago. Hope this helps.
Midwest Airlines- 1984-2010
KPHXFlyer
Sat Nov 22, 2008 4:41 am
Date of last FS flight: 2008-November-8
FS8/FS9/FSX: FSX
Aircraft: POSKY - 757-200
Airline: US Airways
Livery: New US Airways (Post-2005)
To: Phoenix, AZ
Is this a real scheduled flight: Yes, just not at the time I flew
Flight number : US Airways #47
Published Departure Time: 11:30 PM (Hawaii Time?)
Published Flight Time: 6h
Published Arrival Time: 8:30 AM (MST)
Actual Departure Time: 11:45 AM
Actual Flight Time: not real sure (used Time Compression)
Actual Arrival Time: It was still bright sunshine when I got to Phoenix
Pre-Flight Procedure: Flight loads with MS flight programmed, Jeppensen weather, parked at the gate with engines on. turn the engines off, open door L2. Simulate loading passengers (a little TC), Close the door, pushback while turning the right way, turn the engines on, call ATC for VFR departure to the east. Cleared for taxi to Runway 3.
Programs to be used on pre flight / during flight: MS Flight plan VFR from LIH (KHLI) to PHX (KPHX).
CRZ Speed: 475 Knots
SID:
Route: VFR - PHLI to KPHX
Were did you get this route from: FSX Flight Planner
Is this a real world route: Probably not
STAR:
PAX:
LAPS:
Flight Deck Crew: 1 (me -  Smile )
Cabin Crew:
Take Off notes:
Climb notes:
CRZ notes:
Descent notes: at 125 NM out, drop down at 1500 FPM, level off 10000 feet at 50 NM out.
Landing notes: Approx Runway 8. Getting from 10000 to Runway 8 took a few 360s to get down to the right approx path and still ended up on the high side.
IFR Hours Logged:
VFR Hours Logged:
phatfarmlines
Sat Nov 22, 2008 10:14 pm
Date of last FS flight: 11/8/08
FS8/FS9/FSX: FS9
Aircraft: BAE-146
Airline: Air Canada Jazz
Livery: Current
To: ATL
Is this a real scheduled flight: Yes, but not on 146 equipment
Flight number : Don't Remember
Published Departure Time: N/A
Published Flight Time: N/A
Published Arrival Time: N/A
Actual Departure Time: 9:00 pm EST
Actual Flight Time: 2:00 approx.
Actual Arrival Time: 11:00 pm EST
Pre-Flight Procedure: Parked at satellite concouse in YUL. Engines off.
Programs to be used on pre flight / during flight: GPS
CRZ Speed: .75 mach
CRZ Altitude/s: I think 32,000
SID: Takoff from 24L, right turn towards BTV
Route: FS generated high-altitude route
Were did you get this route from: FS9
Is this a real world route: unknown
STAR: close to MACY4
Weather en route notes: clear
PAX: 72
LAPS: 0
Flight Deck Crew: 2
Cabin Crew: 2
Total Souls on board: 76
Take Off notes: uneventful
Climb notes: uneventful
CRZ notes: uneventful
Decent notes: uneventful
Landing notes: required faster landing speed due to UA 319 behind me also landing @ ATL
Post-Flight Procedure: Parked at Concourse D in ATL. Engines off.
Night time Hours Logged: 2
IFR Hours Logged: 2
VFR Hours Logged:
GZIP: Off
