mke717spotter
Need Help With Two Things In FS9
Mon Mar 16, 2009 2:53 am
Like the title says I need some help with two things concerning Flight Simulator 2004:
1.) Anyone know where I can download the MRAI install wizard?
2.) How do you remove the default comercial airline traffic? I used the package from project ai that's supposed to remove it, but for some reason that didn't remove it.
Thanks!!!
UA772IAD
RE: Need Help With Two Things In FS9
Mon Mar 16, 2009 6:15 am
Quoting Mke717spotter (Thread starter):
I don't have it myself so I can't tell you if this works, but try here:
http://aifs.pvdveen.net/download.htm
Have the same problem myself, please post here if you find a solution...
Longhornmaniac
Mon Mar 16, 2009 8:40 am
Hmm...I used the PAI package and it worked just fine for me. Maybe give it another whirl?
Cameron
Cameron
phbuf
Mon Mar 16, 2009 7:47 pm
rename, remove or delete this file..SceneryWorldscenerytraffic030528.bgl
United_fan
Mon Mar 16, 2009 7:51 pm
Quoting PHBUF (Reply 3):
I just deleted all the default planes from the aircraft folder.MD83/747/737/Dash 8/777.
Champagne For My Real Friends,and Real Pain For My Sham Friends
phbuf
Mon Mar 16, 2009 8:01 pm
of course that is a possibility too, but the traffic file literally contains the flightplans and such..remove or rename that file and the traffic is gone, while you can still use the default planes (if you want to..lol)
mke717spotter
Tue Mar 17, 2009 3:30 am
Doing this won't remove GA traffic or other AI I've installed like PAI? Thanks!
phbuf
Tue Mar 17, 2009 2:41 pm
nope indeed, it will only remove the 'default' AI traffic (737, 747, 777, DC-3, etc etc). Other traffic files, like PAI, will have a different file name.
United_fan
Wed Mar 18, 2009 3:05 pm
Quoting PHBUF (Reply 7):
Don't waste your time installing PAI. Stick with WOAI.
BAW076
Wed Mar 18, 2009 7:43 pm
Quoting United_Fan (Reply 8):
Disagree!
Do your own custom traffic! Yes, its time consuming and you need to know what you are doing, but its easy to learn and the rewards are better than any pre-made AI package!
BAW076
N754AN (x2), G-CPEL, G-MIDE, G-BPEC, G-BZHC, EI-DCH, LN-KKN, G-VIIW, G-BNLT, G-DBCA, G-MEDE, G-DBCE, G-MIDP.
mke717spotter
Thu Mar 19, 2009 4:18 am
I have made some of my own custom AI, but the only problem is that the ATC won't call them by their proper callsign. For example, USA3000 which should be "getaway" is just refereed to as a number like "3744".
BAW076
Thu Mar 19, 2009 2:52 pm
Quoting Mke717spotter (Reply 10):
In that case, check AVSIM for a callsign modification "Getaway" for the editvoicepack (you need that too), and it should work (if there is one made for it!).
BAW076
UA772IAD
Tue Mar 24, 2009 9:35 am
What about Word of Ai Files... are these affected by modifying this file?
masped
Tue Mar 24, 2009 5:35 pm
Quoting UA772IAD (Reply 12):
No. This file ONLY affects the default traffic. All other AI packages create their own traffic files.
