klm672
Expressjet AI Not At Gates For KCLE2005 Fs9
Sat Apr 25, 2009 1:42 am
I downloaded KCLE2005 for FS9 by Shehryar 'Shez' Ansari (CLE2005.zip) and everything works fine for AI (for the most part) but I noticed that most of my Expressjet AI park at the hanger (and sometimes at A using the SWA gate) vs at Terminal C and D which they should be at. Now, I haven't been to CLE in about a year but i was hoping to have C and D lined up with Expressjet planes but to my disapointment they weren't. I've downloaded a few different AFCAD files but the same thing happens each time its the same deal. Can anyone help?
[Edited 2009-04-24 18:47:10]
csturdiv
RE: Expressjet AI Not At Gates For KCLE2005 Fs9
Sat Apr 25, 2009 2:56 am
The AFCAD file probably doesn't have any gates coded for Expressjet, or if it does, they might be too small for them to park there. Also, do your aircraft.cfg entries for the ExpressJet birds have their correct parking info in them?
atc_parking_codes=BTA
atc_parking_types=GATE
or some AFCADs might have it as COAX for the Continental Express parking.
An American expat from the ORD area living and working in SYD
phatfarmlines
Sat Apr 25, 2009 7:37 pm
In addition to what Csturdiv stated, you may want to see if the AFCADs use radius measurements as opposed to ICAO coding. What I mean by this is the AFCAD author may change the radius of a gate such that a specific plane parks there and lines up with the jetway correctly. An example would be changing the radius of a gate for an MD-80 as opposed to a 737-700. When you use the default "small" gate, both aircraft are able to park there, but because of the length of the MD-80, it juts forward from the jetway moreso than the 737-700. The radius adjustments make it such that an MD-80 is the only aircraft to park at the gate, leaving the 737-700 to find another gate. There's a whole list of radius adjustments for specific aircraft at ProjectAI.com.
Personally, I'm not a big fan of radius adjustments. I'd prefer using the default gate settings and accepting that the MD-80 may look unusual if its not lined up perfectly to the jetway. The radius adjustments are tedious and can get complicated if you have many types of aircraft at an airport.
One final item, for the Expressjet ERJs, if you do plan on using the default, make sure you use "Ramp GA Large" for the ERJs.
