DAL7e7
FS9 Vs. FSX For A Laptop
Thu Jul 16, 2009 11:07 pm
Hey guys,
I just got a new laptop. HP Pavilion dv4 w/ 380GB HD, 4GB RAM, and 1.7GB Video Memory and Windows Vista. I was wondering if it would be more beneficial to put FS9 or FSX on it. On my desktop, I'm having loads of FSX problems with a much faster machine.
Any input is appreciated.
Trey
DAL7e7 is wondering... Do pilots take crash courses?
fatmirjusufi
RE: FS9 Vs. FSX For A Laptop
Thu Jul 16, 2009 11:21 pm
Well, I'd suggest going with FS9. It's not that bad though.
Here are my specs and I'm still using FS9. Never tried X version.
Intel Core2DUO E8400 @3.0GHz
2GB RAM Patriot 800 MHz
500GB HDD 7200 rpm
nVidia 9600GT
But on the other hand if it's possible to get informed about your CPU and GPU. You haven't noticed.
Fatmir
DO FLIGHTS. NOT FIGHTS.
jasond
Tue Jul 21, 2009 4:21 am
Generally on most comparable configurations FS9 will run faster than FS-X, the margin will vary. I still use FS9 on a Core2Duo 2.8Ghz (4Gb Ram) with a 9600 and it runs really well 50+ fps everywhere with everything on. I also ran it on a similar spec on a laptop and it ran slower 30+ fps but the difference was naturally the graphics capability. Once you get to Core2 the difference is always the GPU. I can't comment on FSX as I tried it briefly, didn't like it and sold it on. Just seemed a bit generic and 'cartoony' for me.
flymia
Tue Jul 21, 2009 3:04 pm
FS9 will be your best bet with the laptop, but it can mess up a little bit with vista in my experience I was only FSUPIC was not installed which messed up some add on's just had to reinstall it. I run FS9 on a 6 year old Sony Desktop and plan on running it on it for a few more years until I am out of school and get a job etc.. I only get 20fps but it is still works fine. Only problem I have is loading up newer add ons but once they are loaded I dont have any problems.
Burkhard
Wed Jul 22, 2009 10:26 am
If I read correctly that your Laptop has a video adapter with 1.7 GB of dedicated RAM, FSX should do very well. If these 1.7 GB are shared forget FSX. FSX needs a real grafics adapter with 320 MB of dedicated video RAM, then it is way faster than FS) to display the same. But putting the huge high resolution textures over a shared memory bus is no good idea.
DAL7e7
Wed Jul 22, 2009 3:28 pm
I own them both already, and I tested them, and FSX was like flying frame-by-frame. Everything looked great, but the detail wasn't worth the crappy framrates.
I can buy extra scenery and stuff to make FS9 look like FSX, right?
Trey
Burkhard
Thu Jul 23, 2009 12:55 pm
No way. Even with the best FS9 addons out there, FS9 grafics are limited significantly. As long as you stick to large airports and airliners, the difference is less visible, but when it comes to scenery, bush flying or even photo scenery FS9 is just a cartoon compared to FSX.
One when you feed FSX with FS9 content, this does not look better.
DAL7e7
Fri Jul 24, 2009 2:56 am
Quoting Burkhard (Reply 6):
Well, not exactly, but I can get it close, right?
I'm having severe FSX problems right now, to the point of uninstalling and reinstalling it. I'm pretty fed up with it. My desktop was built to handle it, and it still crashes all the time.
Anyone else have these problems?
Trey
Burkhard
Fri Jul 24, 2009 9:29 am
Quoting DAL7e7 (Reply 7):
No. With FS9 ground textures have a pixel size of 5x5m, with FSX almost everything is possible - and you need 1x1 or at least 2x2 to recognize a railway. In FS9, railway lines are 50 m wide and still hard to recognize. No way to make a scenery for FS9 that has a resolution that is not 25 times worse than what Google Earth has for most of the world now.
3d Objects doen't show proper reflections of the sun and other primary light sources, ...
Compare the richness and detail of FSX autogen with the low resolution primitive stuff in FS9.
The step from FS9 to FSX is like from a Cessna 150 to an A380.
FS8/9 use the same principle grafics, and that just is almost 10 years old now.
I use FSX heavily every day, and have only once had a series of crashes that I could pin down to a mistype I made in an aircraft.cfg file. FSX after SP2 is the most stable and reliable MSFS I ever had, and I produce FS addons since FS5.1 .
wntex
Tue Oct 20, 2009 3:34 am
yes! i was quite pissed at myself initially. i bought a new PC just for FSX (pretty decent specs) and either have to really water the graphics settings or suffer with a really slow frame rate. so, i still use FS9 and enjoy it thoroughly.
and yeah, i reinstalled it several times, tried to optimize everything, and nothing helped. thanks mircrosoft  Yeah sure
cheers
WNTex
"The chief cause of failure and unhappiness is trading what you want most for what you want now." -Zig Ziglar
