aak777
How To Improve My FSX Display?
Fri Sep 04, 2009 12:05 pm
with these display sittings
Big version: Width: 805 Height: 607 File size: 72kb
Big version: Width: 811 Height: 605 File size: 60kb
Big version: Width: 804 Height: 608 File size: 74kb
i still get this ..
Big version: Width: 1680 Height: 1050 File size: 137kb
can you pleas help
thanks
UltimateDelta
RE: How To Improve My FSX Display?
Sat Sep 05, 2009 1:40 am
Well, I've found that the general settings in the Settings page are the ones that make a difference in the appearance of the aircraft. (the ones with the mormal slider bars that appear up front) I assume that that is also true for the scenery., but I'm not certain. Hope this helps!
Midwest Airlines- 1984-2010
aak777
Sat Sep 05, 2009 10:43 am
thanks for the reply
i am already using MAX for the aircraft at least
Big version: Width: 1028 Height: 740 File size: 93kb
but still.
appreciate an other ideas.
thanks
Fly2HMO
Sat Sep 05, 2009 8:09 pm
Turn on anisotropic filtering. That should fix it.
Otherwise it could be a driver issue.
Do all your planes look like that?
FX772LRF
Sat Sep 05, 2009 11:03 pm
I had this same issue before I got my new video card for FSX. That may be your problem.
If you could, post your computer specs here, and maybe we can troubleshoot for you.
-Noah  wave
Cleared to IAH via CLL 076 radial/BAZBL/RIICE3, up to 3k, 7k in 10, departure on 134.3, squawk 4676, Colgan 9581.
aak777
Sun Sep 06, 2009 1:40 am
Quoting FLY2HMO (Reply 3):
it is the same for all planes.
I turned on the anisotropic filtering and reinstalled the driver but, no..
thanx for the help any way
Quoting FX772LRF (Reply 4):
here. appreciate any suggestions
Big version: Width: 494 Height: 164 File size: 12kb
aak777
Sun Sep 06, 2009 2:18 am
and the NVIDIA GeForce 8600 GT 1GB
I couldn't figure out the motherboard.
YXD172
I had the same issue for the longest time, ugly aircraft with 'Aircraft' set to the max.
IIRC, if you move the 'global texture resolution' slider (Graphics Tab) up to High/Very High the aircraft will look much better.
Jon
Radial engines don't leak oil, they are just marking their territory!
aak777
Sun Sep 06, 2009 8:55 pm
Hi all
My planes are back to normal now, all i did was change the "default cock pet view" from 3D to 2D, It seems to me irrelevant because i changed it back and it stayed. It must have tregered something.
Thanks all any way.
FX772LRF
Sun Sep 06, 2009 11:41 pm
Quoting Aak777 (Reply 8):
Hi all
Thanks all any way.
Glad to hear. No problem.
Moderators, I think it'd be acceptable for this thread to be locked.
-Noah  wave
