76794p
Problem With FSX
Mon Jan 04, 2010 7:39 pm
My problem is that i can acess the main area i.e were you choose the plane and airport and that kinda of stuff, but when i click fly now i gives me a black screen and the only thing that happens is that a black screen shows up and then i wait and have to end the program since it is not responding. What should i do. i re-installed it because i had to restore my computer since some freeware messed it up.
There's always money IN the banana stand.
Burkhard
RE: Problem With FSX
Tue Jan 05, 2010 8:34 am
Are you sure that the (partial) mess up is gone, so did you check that the FSX main folder got deleted, the all user profile and your own user profile of FSX got removed?
How long did you wait. The first FSX startup can take up to 10 minutes on a system with bad fragmentation or a slow disk, FSX not resonding in this time since it builds up.
Another idea might be that your system has problems to go to the Full Screen mode, or wants to issue a message that displays behind the full screen ( in this case you do not see the message and the system waits for you to click OK to a message that might be easy to fix. Since FSX runs full screen with effectively half resolution of windowed only anyways, try to start in windowed mode...
If this does not help, ask the question with some more details on a dedicated FSX forlum like the one at flightsim.com.
Maverick623
Tue Jan 05, 2010 10:52 am
What are your system specs? It sounds like you don't have enough memory to run it.
"PHX is Phoenix, PDX is the other city" -777Way
76794p
Tue Jan 05, 2010 11:40 pm
Quoting Maverick623 (Reply 2):
I have a 500 GB drive and 4 gigs of ram. I also 1GB video card.
Burkhard
Thu Jan 07, 2010 10:30 am
FSX does run on much lower hardware...
Maverick623
Sat Jan 09, 2010 8:12 pm
Quoting Burkhard (Reply 4):
Indeed, as my system is almost exactly half of his!
takisG
Fri Jan 22, 2010 4:47 pm
I am an FSX player , rather than FS2004, but I find every so often that my game crashes randomly- Lets say every 2 hours.
My specs are:
Nvidea 9800 GTX
4 G RAM
Could this be a problem related to the hard drive?
Cadet985
Sun Jan 24, 2010 4:36 am
Different problem here.....is anyone running FSX on Windows 7? I can't get it to fill my screen. It loads, planes fly okay, but the screen only loads in the middle. It kind of looks like letterbox format, but there are black bars on the sides.
takisG
Thu Feb 11, 2010 1:25 pm
Check your screen resolution, I use 1440x900x32.
If your screen resolution is too low, this may cause resolution problems with the default screen resolution on the PC.
Burkhard
Fri Feb 12, 2010 10:03 am
There is a problem with W7 and full scrren mode - run in windowed mode and you have better visuals, better performance and less problems.
