detroitflyer
Can This Laptop Handle FSX
Thu Mar 25, 2010 4:55 pm
Hey all,
I am buying a new laptop, primarily for school, but I would like one that can run FSX pretty decently. I have a price range from $600-700, and cannot afford anything more than that. I was looking at these 2 models, which have dedicated graphics and 2.2. ghz processors. Are they any good, and if not can you point me to whatever is best in this price range.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220701
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16834115727
thanks
Boiler Up!!!
Fly2HMO
RE: Can This Laptop Handle FSX
Thu Mar 25, 2010 6:30 pm
I'm afraid neither one of them will cut it (as mush of a fan of Asus I may be). Video memory is too small and the video cards are entry level, also they have AMD processors which are horrid. For FS9 they will probably be just barely enough to run fully maxed out but for FSX forget it.
At the very least you want an ATI HD5xxx video card with 1GB of dedicated memory and a Core i3, MAYBE a core 2 duo.
Unfortunately for that price range I can't find anything that will do the job. If you want to play FSX with no problems you're gonna need at the very least $1200
detroitflyer
Thu Mar 25, 2010 8:36 pm
Is there a difference between an intel i3 clocked @ 2.2ghz and an AMD clocked @ 2.2 ghz. I mean dont they run at the same speed after all. Also what type of memory should I get, I thought 4 gigs of ram would be good??
Sorry, Im not really familiar with all these specs, but thanks for the help anyways.
Boiler Up!!!
Fly2HMO
Thu Mar 25, 2010 10:54 pm
Quoting detroitflyer (Reply 2):
You can't rely on mhz or ghz to judge processor speed anymore. A new Core i7 at 2.66ghz is ridiculously faster than an older Pentium 4 at 3.4Ghz. Without getting too technical basically new processors are much more optimized in terms handling information, amongst many other improvements.
And notice how Intel is always ahead of AMD in tests:
http://www.tomshardware.com/charts/m...e-cpu-charts/3DMark06-CPU,464.html
It should suffice. But don't get anything under 4gb.
