Virginblue4
Landing In Flight Simulator
Sun Sep 12, 2010 2:55 pm
Hey simmers,
Landing? Help?
I sometimes do an ILS approach, and SOMETIMES it works, other time it doesnt. I do all the 'NAV1' things etc and switch the little switch to 'Approach' sometimes it flies towards the airport when its close, other times it just flies straight past, any tips?
And now onto Manual Landings
I tend to fly 737's 767's and 787's
What kinda speed should I approach the runway at? I usually do it at around between 180-200 kntos, and i only press the flaps button twice, anymore and i seem to float and miss the runway. Any other tips?
Also lining up with the runway? Unless its ILS (which doesnt always seem to work) i end up too far left or too far right, as ATC never direct m exactly to the runway, Please help.
Jordan
The amazing tale of flight.
kcrwflyer
RE: Landing In Flight Simulator
Sun Sep 12, 2010 3:16 pm
Quoting virginblue4 (Thread starter):
Slooooooow doooooown! While these planes can all land with the lowest 2 or 3 flap settings, go ahead and use full flaps. There are charts all over that show landing speeds, but you really don't want to be above 150-160 on final approach.. and that may be pushing it.
Well if you're hand flying, that one's all on you. Just keep practicing.
Gingersnap
Sun Sep 12, 2010 4:16 pm
This is where payware aircraft really come into their own.
However, in terms of hand flying the approach...just keep practise and make sure you using all the in-cockpit aids as well as visual aids (VASI etc).
My general rule is...
Intercept the localiser at around 170-180 and immediately slow to around 160.
At around 5-7 DME, I lower my last stage of flap and slow to VREF+5 (which on most 737 sized aircraft, is around the 140-150 mark but sometimes less I find). Of course, determining the VREF can be difficult without the correct documentation and payware addons.
Flaps for example help to create lift, to keep the aircraft in the air at slower speeds. Full flaps at 200 KIAS, will not only send you floating away almost...it should in reality do quite a bit of damage to things
On the PMDG 737 for example, I set the speed to my final APP speed and the aircraft will 'retard' the throttles automatically just prior to touchdown.
On any aircraft without this ability...I like to leave the AT on until around 2-3 DME and then take over the throttles. The best advice I can give, is lower the workload as much as possible with what you have.
On a visual, its unlikely you will be exactly centered when the ATC turns you in for final. Too many variables like bank angle, speed, wind etc to allow for that kind of accuracy. Of course, they turn you in and won't clear you for approach until the runway is in sight. After that, it is up to you to line up correctly (and with enough distance to allow for a margin of error) and fly the approach down to the TZ.
I once forgot to call "runway in sight" to ATC, and they sent me on a missed approach
Just keep at it and you'll pick it up in no time.
Flown on: A306 A319/20/21 A332 B732/3/4/5/7/8 B742/4 B752 B762/3 B772/W C152 E195 F70/100 MD-82 Q400
EDICHC
Mon Sep 13, 2010 9:35 am
Quoting Kcrwflyer (Reply 1):
For the 737, full flaps and speed down to 135-145 KIAS on final. One principle that holds in flying (no matter what a/c type), is that the quality of your landing will be determined by how well and how early you are set up on final approach.
No harm in going back to the flight school in FS to brush up a bit.
A300/319/320/346 ATR72 B722/732/3/4/5/6/8/742/4/752/762/3/772/3 BAC111 BAe146 C172 DHC1/6/8 HS121 MD80 PA28
Fly2HMO
Mon Sep 13, 2010 9:39 pm
Landing? Help?
One word: Google.
Memorize approach profiles. Probably a bit too advanced for you at this point but you'll get the jist of it:
http://www.flightsim.com/howto/fly737/fly737_html_m6517e79d.jpg
Using the same profile every time will help you consistently make better approaches and landing.
KevinL1011
Tue Sep 14, 2010 4:12 am
I confess that I too have some difficulties with manual landings. My problem is maintaining 135 to 145 kias without having the nose too high. When I push the nose down, my air speed starts climbing. If I back off the throttle, I sometimes get a stall warning. I don't have tail strikes but sometimes It's close. Any suggestions?
474218, Carl, You will be missed.
cpd
Tue Sep 14, 2010 4:50 am
Hi Kevin,
Try to maintain correct pitch angles, and then adjust or remove power to have the correct speed. You may well need to keep modulating the throttle continuously.
Look at the weight of the plane (heavier plane means faster landing speed) - then take into account weather (eg, windshear), add any windshear to the vREF (eg, vREF+10 for 10kt winds, or less if you consider that's okay) and then fly the plane in at that speed.
Some planes are easier than others in FSX. I have the feeling in FSX that Concorde (The FSL one) is very easy to land, much like the PMDG 747-400 is, while the MD-11 I always seem to find a bit more difficult since the slightest throttle applications seem to have abrupt effects on the speed.
[Edited 2010-09-13 21:54:04]
United_fan
Tue Sep 14, 2010 5:13 pm
I have had that problem at some airports. Sometimes I capture the localizer,click 'app' and the plane nose dives. Some aiports it swerves off wildly. I have been 'simming for 10 years,so I know what I'm doing
Champagne For My Real Friends,and Real Pain For My Sham Friends
cpd
Tue Sep 14, 2010 10:28 pm
I might also warn about auto throttle use. While it can be of great utility in some situations, its destabilising effect when hand flying must be appreciated (due to automatic maintenance of speed at all times).
Smooth flying in that situation should be exercised and you should keep a careful watch on vertical speed to prevent excursions from the assigned flight level.
[Edited 2010-09-14 16:21:19]
BA777
Wed Sep 15, 2010 5:35 pm
Quoting KevinL1011 (Reply 5):
What aircraft? The approach speed real aircraft flies varies on many things but one of the major factors is mass. The heavier you are, the faster you have to fly to avoid stalling. Do you fly the aircraft with full fuel? For example, fly a 747 from LHR-AMS with full fuel and you can bet your house you will be above the max landing weight for the aircraft!
Real airliners approach 30% above their stall speed to give you enough margin. Try landing the 737 with about 2,000kg in the tanks and you should have no problems.Obviously the default aircraft have shocking flight dynamics which could be part of the issue.
kcrwflyer
Wed Sep 15, 2010 5:39 pm
Quoting ediCHC (Reply 3):
Really? In a heavy 8-900?
Gingersnap
Wed Sep 15, 2010 9:35 pm
Quoting Kcrwflyer (Reply 10):
At a good landing weight, then yes even in the 8/900 (at least the PMDG version) are around 130-150 KIAS on finals at the very most.
I flew a FR 738 earlier and my Vref was 131 w/ 40 flap.
EDICHC
Thu Sep 16, 2010 4:51 am
Yeah pretty much. Though I don't very often fly the 800 and never a 900. I prefer the baby 737's, 3/5/6/700s.
As others have pointed out weight is pretty crucial as well. You carry too much excess fuel, you are gonna sink like a stone at 'normal' approach speeds. I have set down an admittedly lightly loaded 733 at an astonishingly low speed of 108 KIAS and an approach speed of 120 KIAS (I was doing some silly stuff trying to land at an airport with a very short runway that usually just manages a BAe146 with weight penalties!)
KevinL1011
Thu Sep 16, 2010 6:04 am
Quoting cpd (Reply 6):
I'm still getting a feel for that and often not using live weather updates. I'm not as advanced as most around here. I think my problem is that I'm putting in too much flare trying to grease it in.
Quoting cpd (Reply 8):
Yeah, I crashed the A-321 a few times because of that and haven't done it since.
Quoting BA777 (Reply 9):
I usually fly the FSX 737-800 or the Vistaliners L-1011 with default fuel which is about 58%. Funny you should mention the 747 fully fueled. I tried it once with full load and fuel @ LAX on 24R and ran out of runway. Luckily the terrain slopes down to the shore.
Yeah, the default 737 has most of the fuel weight in the center tank and the default A-321 has pretty much equal center and wing loads. I assume you mean 2000kg per tank and do you recommend equal loads, not a center tank biased load?
Quoting GingerSnap (Reply 11):
OK, so I'm pretty much in the window @ 145kias.
Thanks everyone for your input!
Maverick623
Thu Sep 16, 2010 7:28 am
Any suggestions?
Don't worry so much about where the nose is pointed in relation to your descent rate.
Just fly at 140-145kts, maintaining a 3-5 degree nose-up attitude and a 700FPM descent rate. In fact, if you only focus on any two of those you'll find the third just seems to happen by itself.
"PHX is Phoenix, PDX is the other city" -777Way
cpd
Mon Sep 27, 2010 1:05 am
Quoting KevinL1011 (Reply 13):
That's one of the worse FSX planes - I don't think it flies too well at all.
The documentation of FSX planes has landing speeds - it's worthwhile reading that. I can't really offer that much extra help on the default planes as I rarely fly them. It's also worth knowing the approach pitch angles - I know for Concorde I can go up to 10.5 degrees - and you balance that with the correct speed, all else should fall into place fairly easily.
airbalticfan
Mon Sep 27, 2010 3:03 am
Default airplanes in FSX are far away from reality, so to speak, almost unusable.To get best results you will need to spend some money so you can fly nice payware aircraft.In A320 if you maintain about 135-145knts you will be fine, at least this speed always work for me.
EDICHC
Mon Sep 27, 2010 4:01 am
Quoting Airbalticfan (Reply 16):
There are some pretty good freeware aircraft out there as well...the Project Opensky and Project Airbus ones in particular, spring to mind for good flight dynamics.
cpd
Tue Oct 05, 2010 1:11 am
Kevin: Here is a good document for you to reference too:
http://www.smartcockpit.com/pdf/flightops/flyingtechnique/2
This is one from Airbus that has many good points. Look carefully at the power curve (thrust required to fly). Lower speeds need more thrust to fly (more pitch up attitude). But higher speeds make it less easy to be stabilised in the right amount of time.
Venturing near the back of the power curve means you have less thrust available to you (because you need more thrust just to fly). Higher speeds (less pitch angle) mean you have more thrust available.
And here is another good one:
http://www.smartcockpit.com/pdf/flightops/flyingtechnique/48
As always, rushed and or high/fast approaches are a recipe for being unstabilised and/or experiencing runway excursions. If it isn't stabilised, go around.
Avoiding tail-strikes:
http://www.smartcockpit.com/pdf/flightops/flyingtechnique/9 (Boeing)
http://www.smartcockpit.com/pdf/flightops/flyingtechnique/8 (Airbus)
The Boeing one has good information.
[Edited 2010-10-04 19:04:04]
NAV20
Sun Oct 24, 2010 3:50 pm
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
Virginblue4
Sun Oct 24, 2010 9:18 pm
Thank you so much NAV20, that's fantastic!
Jordan
Fabo
Tue Nov 02, 2010 6:59 pm
I found some things worth commenting on...
Should be a bitch in real life too.
142kts Vref for MLW 738 (some 66 tons) at 13C and presure altitude 1200ft.
737 is supposed to have all fuel in wing tanks untill full. Only then you put fuel in center tank. I believe A320 family is similar.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
