klm672
Misaligned Text On FSX
Fri Oct 15, 2010 7:03 pm
Hello. I was wondering if anyone else has this problem and if there are any solutions. It seems that text is misaligned on FSPassengers, Map! (as seen in this screen shot). It also carries through to the panel... look at the 3rd throttle power, the "bolded" white line is misaligned along with the "330" on the far right. I've also noticed this on my Default GPS. How does I set the AA outside of the sim?
And for what it's worth, this did not happen when I had FS9. ! It doesn't matter if I move the boxes, make them bigger or smaller it still looks like the text isn't completely lined up.
Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.100608-0458)
Language: English (Regional Setting: English)
System Manufacturer: Gateway
System Model: FX6800-01e
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (8 CPUs), ~2.7GHz
Memory: 3062MB RAM
Page File: 2988MB used, 3349MB available
Windows Dir: C:Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
DxDiag Version: 7.00.6002.18107 32bit Unicode
Display Devices
Card name: ATI Radeon HD 4850
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor (0x9442)
DAC type: Internal DAC(400MHz)
Device Key: EnumPCIVEN_1002&DEV_9442&SUBSYS_E810174B&REV_00
Display Memory: 2294 MB
Dedicated Memory: 1019 MB
Shared Memory: 1275 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: atidxx32,atidxx64.dll,atiumdag,atiumdva,atiumd64.d ll,atiumd6a.dat,atitmm64.dll
Driver Version: 7.15.0010.0127 (English)
DDI Version: 10.1
BGRA Supported: No
Fly2HMO
RE: Misaligned Text On FSX
Tue Oct 19, 2010 3:56 am
Looks like texture tearing. First off, you have very old drivers. ATI Catalyst 10.10 drivers should be out by now. UPDATE THEM MONTHLY. This is very important. That may fix that.
Otherwise, sounds like a vertical-sync problem. Open catalyst control center and set Vertical sync to default on.
As for AA. DON'T use the FSX graphics settings for anti-aliasing, change them directly on the ATI Catalyst control center.
klm672
Wed Nov 24, 2010 7:03 pm
Hey,
I tried everything you said but no luck. I am unable to find the 10.10 drivers. Any other suggestions?
klm672
Mon Dec 03, 2012 12:17 am
I am still having this issue, When I click "update drivers" it says that everything is up to date..
klm672
Sun Jun 07, 2015 3:34 pm
Can anyone provide any guidance on this?
Thank you!
N415XJ
Sun Jun 07, 2015 5:21 pm
Aviation hobby is a relatively small and lightly visited section of the a.net forums, so getting technical help for FSX here is difficult. I'd advise you to go over to avsim.net and make a (free) account on their forums. You'd be able to get some help in about 5 hours instead of 5 years.
klm672
Mon Jun 08, 2015 3:40 pm
Thank you
The message you were about to post is too short and probably not of any higher value to the topic at hand. You should think long and hard before posting a message in this forum and make it detailed and a valuable addition to the topic discussed.
Avoid posting "Me Too" messages. These are messages that are posted by people who agree to a point being discussed and post a one liner, "me too!", "Good post Jim!", "I disagree" or similar message. This takes up time as readers must sort through these messages which have no real value to the group at large. Any message containing nothing more than a line or two of text is probably not worth posting.
If you have an opinion on a topic, you should in detail express why you have the opinion and what made you come to that conclusion.
Your post should be relevant to the topic discussed.
Users browsing this forum: UltimateDelta and 5 guests
