Cadet985
FSX Callsigns
Sun Jul 31, 2011 3:20 am
Okay, I know this is really a non-issue, but is there a way in FSX to actually get ATC to pronounce airline callsigns? I'm tired of having a BA flight for example, and not have the callsign pronounced, and just be called "xxx heavy."
B737200
RE: FSX Callsigns
Sun Jul 31, 2011 4:47 am
Try this:
http://www.editvoicepack.com/
I've only ever used it on FS9 but according to the website it also works with FSX.
Lady Guinness is ready to fly...
Cadet985
RE: FSX Callsigns
Sun Jul 31, 2011 8:47 am
Is the program itself (editvoicepack) known to crash...a lot?
B737200
RE: FSX Callsigns
Sun Jul 31, 2011 9:49 am
I don't think it ever crashed for me. I have the FS9 version though. I've used it on Windows 7 64-bit.
I don't really know what the problem can be, maybe someone else can help you more than I can.
Does it even start? And did you install it using the "Run as Administrator" function?
Cadet985
RE: FSX Callsigns
Sun Jul 31, 2011 10:09 am
I'll try it later today...I've been having so many issues with FSX and add-ons for it that I'm seriously ready to uninstall it for good.
drerx7
RE: FSX Callsigns
Sun Jul 31, 2011 3:03 pm
I have editvoicepack for FSX and it works and I don't have any problems with it at all. Cadet985 - try reinstalling, I really don't have issues with FSX.
Third Coast born, means I'm Texas raised
UltimateDelta
RE: FSX Callsigns
Sun Jul 31, 2011 3:43 pm
Sometimes you just have to use weird variations. For example, all my BA aircraft use 'Speed Bird' instead of 'Speedbird'. Of course, Editvoicepack is probably a better permanent solution, but I'm just putting that out there.
Midwest Airlines- 1984-2010
Burkhard
RE: FSX Callsigns
Mon Aug 01, 2011 11:35 am
EDVP 4.0 works very stable, I have created about 1000 callsigns for it.
Now, the call sign that is uses is written in the aircraft.cfg. If there you find am ATC_airline=Speed Bird, Speed Bird will be used, and if you have speedbird there, speedbird will be used. Checking through the literature, you find both ways of spelling.
Cadet985
RE: FSX Callsigns
Mon Aug 01, 2011 11:47 am
I'm having trouble importing various callsigns...all I want are some of the major and regional carriers.
B737200
RE: FSX Callsigns
Mon Aug 01, 2011 6:21 pm
This is what I do (disclaimer I do this for FS9)
1. Go on File and click "Update Voicepack"
2. After you perform an update go on file and click "save."
3. Then go on tools and click on "update airliners.cfg"
You may be actually downloading the call signs but if you do not update the airlines.cfg file they will not show up.
That is my procedure it works for me, let us know if you have any luck.
GEG
RE: FSX Callsigns
Mon Aug 01, 2011 7:19 pm
Quoting Burkhard (Reply 7):
I'll have to try this when I get home, thanks
I have no idea what I'm doing...
Cadet985
RE: FSX Callsigns
Tue Aug 02, 2011 10:05 am
Quoting b737200 (Reply 9):
Followed your instructions, and some callsigns are working...for example, it is pronouncing "Colgan Air" but not Cathay Pacific. Any suggestions?
B737200
RE: FSX Callsigns
Tue Aug 02, 2011 3:33 pm
Then I think you need to download the voice files for those airlines. I'm not where to find them, maybe try avsim.
I'm not sure if AI packages like WOAI come with voice files, maybe you can try downloading the AI traffic for Cathay, installing it and running the update process once again.
Cadet985
RE: FSX Callsigns
Sat Aug 06, 2011 2:42 pm
Quoting b737200 (Reply 12):
I've never been able to get any of the AI packages to install correctly.
Ned Kelly
RE: FSX Callsigns
Sun Aug 07, 2011 4:09 pm
Editcoicepack must be the #1 MUST HAVE freeware addon for FSX IMO (&FS2004, FS2002) if you intend on using non-default AI aircraft or flying non-default aircraft.
A couple of links for info:
http://www.fsonline.dk/en/index.php?title=EditVoicepack
p.s. I have never known this program to cause the compute to crash.
[Edited 2011-08-07 09:10:40]
[Edited 2011-08-07 09:11:27]
