dla320
Sga Md 80 Takeoff
Thu Aug 11, 2011 11:10 pm
Has anybody had any problems with tailscrapping in the sga md 80 models, everytime i attemp to takeoff the back of the plane rides the ground for a while and then starts lifting off the ground. Is it just something that im doing wrong or is it the plane?
alaskamd80
RE: Sga Md 80 Takeoff
Fri Aug 12, 2011 1:23 am
Hi, did you remember to set the trim? that might be your problem...
Luciano
dla320
Fri Aug 12, 2011 2:03 am
Quoting alaskamd80 (Reply 1):
How would i set the trim
usair330
Fri Aug 12, 2011 2:18 am
Quoting DLa320 (Reply 2):
Makes me wonder.... Did you set the flaps for takeoff as well? Rotate speed should also be @ 145 knots, with those aircraft newayz..... (Not %100 accurate)
KPDX
Fri Aug 12, 2011 2:26 am
I think I know the problem you are referring to... I guess one way would be to increase the cruise lift scalar in the aircraft.cfg by 1 or so.
View my aviation videos on Youtube by searching for zildjiandrummr12
kcrwflyer
Fri Aug 12, 2011 4:11 am
I haven't had any problems.
1. stop rotating so steeply
2. check your weights, make sure youre not over weight
3. Flaps ( you should be able to take off on the 2nd-4th settings) and trim. Your trim should be fine by default, that doesn't seem to be the problem since you're getting the nose up.
phatfarmlines
Sat Aug 13, 2011 1:49 pm
Quoting kcrwflyer (Reply 5):
Actually, the SGA/Erick Cantu T-Tail models (DC-9, MD-80, MD-90, 717, 727) require setting the trim for proper takeoff. User DLa320, please go into your FS2004 / FSX commands assignment and find what keys on your keyboard or joystick are used to set the trim. If you are doing this correctly, you should see your horizontal stabilizer move up or down.
The fact that he's getting lift tells me DLa320 is setting flaps, but without the proper trim, is resulting in a very long takeoff roll. Otherwise, we'd have a NW 255 on our hands......
kcrwflyer
Sat Aug 13, 2011 11:50 pm
Quoting phatfarmlines (Reply 6):
If he's dragging the tail down the runway then he's more than trimmed enough.
dla320
Sun Aug 14, 2011 4:35 am
i always set the flaps so i know thats not the problem, its just fustrating that on some runways it take the whole runway and then some to get up
JohnKrist
Crew
Sun Aug 14, 2011 4:42 pm
Default trim is shift+1 (pitch up) and shift+7 (pitch down) if I'm not mistaken. I never remember which so I try both until the plane does what I want
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
kcrwflyer
Sun Aug 14, 2011 5:34 pm
Quoting DLa320 (Reply 8):
Youve never said, how much runway are you using? Also, make sure the plane isnt over weight.
flymia
Sun Aug 14, 2011 8:38 pm
Make sure your not overweight. If you are flying for example DFW-MCI you dont need 100% fuel maybe just put in 40% etc.. Change the passenger numbers etc.. If you are using large 8,000ft plus runways you should have plenty of room to takeoff.
