avi8
Woai Error.
Sun Nov 27, 2011 12:52 pm
Hi, I just installed FSX in my new Windows 7 computer but a,m not able to install WOAI. I can download the packages and the installer but when I begin installing the airline packages I get an error message. I have dobble checked the path the program is using and it all seems ok. Can someone please help me?
avi8
Medschool student
MIAspotter
RE: Woai Error.
Sun Nov 27, 2011 2:51 pm
I had the same issue, try running the program in administrator mode.
To do that right-click on the icon and choose run as administrator, it should be fine
MIAspotter.
Nos vamos de Vueling?
steffenbn
RE: Woai Error.
Sun Nov 27, 2011 11:05 pm
Quoting MIAspotter (Reply 1):
You can also Right-Click - Properties - Compatibility - Run as administrator, this way you can just open it like any other program and it will work!
Cheers!
A330, A319, 737,738,752,763,763ER,764ER,777-200LR
Burkhard
RE: Woai Error.
Fri Dec 02, 2011 8:30 am
And switch the user access control off - you cannot change the content of an application, in this case FSX, in a reproducable way with UAC on...
steffenbn
RE: Woai Error.
Sun Dec 04, 2011 11:50 am
Quoting Burkhard (Reply 3):
Just run everything as administrator - then you are able to do everything with fsx!
-Steffen Nielsen
Burkhard
RE: Woai Error.
Tue Dec 06, 2011 12:52 pm
Quoting steffenbn (Reply 4):
-Steffen Nielsen
This is not always the case, the administrator does not have full control over everything if the UAC decides he should not do it. UAC overrules administrator as user.
Users browsing this forum: Raventech and 1 guest
