SuperBus
Locating Aircraft Folder In FSX
Sun Dec 04, 2011 12:48 am
I am having some difficulties locating the "Aircraft" folder in FSX using Microsoft Windows 7. What shortcuts can I use to locate it? I have tried system searches and nothing seems to be coming up.
SuperBus
Edited for grammar
[Edited 2011-12-03 17:11:16]
David L
RE: Locating Aircraft Folder In FSX
Sun Dec 04, 2011 10:57 am
It's called Airplanes in FSX and it's in the SimObjects folder of your main FSX folder, i.e.
Microsoft Flight Simulator X -> SimObjects -> Airplanes
SuperBus
Mon Dec 05, 2011 3:02 am
Thanks for the information.
Burkhard
Thu Dec 08, 2011 7:53 am
To make it more precise: FSX can have many aircraft folders. Where they are you define in your user fsx.cfg file, there you add lines simobject=.... and then this is known to FSX.
I would not install any addon aircraft that is not aware of this to FSX unless you are a developper yourself and know what you are doing - it is likely to cause problems and will perform bad.
