growley
B777-200 FSX Repaint - Transaero!
Fri May 18, 2012 4:52 am
I just posted a Transaero repaint in the AVSIM library. This B777, registration code EI-UNY, is operated by Transaero Airlines. Transaero operates out of Domodedovo International Airport, Moscow, Russia. It flies to more than 99 domestic and international destinations. On April 29, 2012 Transaero began its inaugural flight from LAX-DME operating with a B777-200. The airline now operates ten B777s.
This repaint has very detailed markings. If you enjoy exterior detail, then you will love this repaint. You can see (and read): Door opening instructions; Static port directions; Air vent warnings; Engine hazard area (English and French); No Step warnings; RAT caution; APU intake warning; Stabilizer compartment access; Interphone jack; Ground power supply; Forward and aft access door instructions; Pitot, ADA probe, Ice detector and TAT probe markings; Visible rivets; Enhanced window frames; Authentic Transaero markings (English and Russian); Boeing look-alike font; Bold, colorful Transaero livery (fuselage and engine); Lovely Transaero flight attendant; No frame rate hit - I get around 50 fps on a laptop
AVSIM Download ID = 168619
Transaero starboard lettering
Transaero port lettering
Transaero tail marking
