lmml 14/32
VFR - Flying The Horizon
Fri May 18, 2012 1:17 pm
I am doing my PPL and am having problems flying steep turns slow flight using the natural outside horizon to maintain my altitude. My problem is that I don't know where the horizon should be with reference to the engine cowl and I keep under/overshooting the bank angle and porpoising a lot to stay maintain a steady altitude. Can anyone suggest a web site with pics on how the horizon should look like in a steep bank?
Mir
RE: VFR - Flying The Horizon
Sat May 19, 2012 6:14 pm
It's going to depend on what type of airplane you're flying, so I don't think we can point you to any one site. But next time you go flying, ask your instructor to fly the airplane while you take your own pictures.
-Mir
Gingersnap
Sun May 20, 2012 12:43 am
As Mir said it depends upon the aircraft you're flying.
I only have hours on C152 only so I only know that aircraft. It's just about hand-eye co-ordination and feeling the aircraft as you execute the turn. I remember as a young budding pilot being surprised at quite how much back pressure needed to be applied to keep the aircraft level.
I can't give you an exact answer as due to lack of funds (child x2) I haven't flown in a year or two. But I do seem to remember the horizon being around 60% up from right to left when in a steep right hand turn.
Similar to this
Flown on: A306 A319/20/21 A332 B732/3/4/5/7/8 B742/4 B752 B762/3 B772/W C152 E195 F70/100 MD-82 Q400
lmml 14/32
Mon May 21, 2012 3:21 pm
Quoting Mir (Reply 1):
Thank you. Now why did this not occur to me?
PITrules
Tue May 22, 2012 5:15 am
For Steep turns, use the bug splatters on the windscreen to your advantage. Pick one closest to your line of sight (one straight ahead and at your eye level). Note its location relative to the horizon before beginning, and keep it there for the duration of the maneuver. Works great for rolling into the opposite turn, as it will be in the same location relative to the horizon. This works across a wide range of airplanes, so no need to memorize locations on an engine cowl for each aircraft.
The first part of this video shows what I mean:
http://www.ehow.com/video_4411869_make-steep-turn-airplane.html
Bug splatters are great for off field emergency landing practice as well. Once established at best glide speed, if the landing site seems to rise in relation to the bug smear, you will not make it. If the field remains stationary or descends relative to the bug smear, you have the distance to make it.
[Edited 2012-05-21 22:25:25]
FLYi
Gingersnap
Tue May 22, 2012 9:23 pm
Quoting PITrules (Reply 4):
That is actually fantastic. I'll need to use that when practising in the future.
lmml 14/32
Wed May 30, 2012 7:30 pm
Great advice. Tried it today and it worked perfectly. Thanks a million. Even my instructor was impressed by "my" idea....
