joperrin89
Justflight MD-81/82 Panel Set Up Help!
Fri Jun 15, 2012 5:37 pm
Just got the Justflight MD-80 and the virtual cockpit panel is cold and dark. All gauges and screens are black. Can anyone step me through how to set it up? Or give me a link that has instructions?
Thanks, Josh
thebatman
RE: Justflight MD-81/82 Panel Set Up Help!
Fri Jun 15, 2012 9:52 pm
Quoting joperrin89 (Thread starter):
Didn't the add-on come with a user manual (usually in .pdf)? There are several walk-throughs on youtube for the md-80...
Aircraft mechanics - because pilots need heroes too!
joperrin89
Fri Jun 15, 2012 10:29 pm
There were 3 "Flight totourials" that came with it in .WX .PLN and .FLT format, none of witch I can open. (Not really a computer person) And I could not find anything on youtube that shows how to start up the 3D panel. :/
flymia
Sat Jun 16, 2012 8:39 pm
There should be PDFs with the add on.
The first thing you will need to do is turn on the master baterry switch, then either connect external power or the APU. This is a just flight plane so it's probably not too difficult to figure out. Find the master battery switch and if you don't know the engine start procedure just press control E.
