MCOflyer
ATC Wont Work In FSX: Need Help
Fri Jun 22, 2012 10:37 pm
My ATC will not work in FSX. However, every other noise will. Does anyone know how to get ATC back working???
KH
Ps76
RE: ATC Wont Work In FSX: Need Help
Sat Jun 23, 2012 1:44 am
Hi!
Sorry I don't have FsX on this computer but thought I'd try. Does the ATC text and options come up when you hit the ATC button (on my PC it's @ I think)? If not it could be the key has been reassigned which you could fix in controls assignments. If the text works but there's no speech I think it's under Options Setting ATC and then check "Use a pilots voice". At least in Fs9 it's like that. Last thing I can think of is under the sound settings maybe ATC has turned down to zero.
Sorry I don't have FsX with me now to give you better advice.
Many thanks,
Pierre
LH707330
Sat Jun 23, 2012 5:54 am
Try pressing ' or SHIFT ' to bring up the screen.
zkojq
Mon Jun 25, 2012 9:31 am
Sometimes ATC won't work for me in FSX when the aircraft's engines or electronics are off. Turning the engines or electronics on may solve the problem.
First to fly the 787-9 (ZK-NZE, NZ103, 2014-10-09)
