bueb0g
Name The Aircraft Quiz
Wed Sep 26, 2012 9:02 am
Hello all,
Here's a quiz I did on jetpunk. Give it a go and let me know if there are any issues with it, or any awkward questions. I know it's a bit easy, I'll do some more challenging ones later!
http://www.jetpunk.com/user-quizzes/28093/name-the-aircraft-quiz
Roger roger, what's our vector, victor?
David L
RE: Name The Aircraft Quiz
Wed Sep 26, 2012 10:33 am
Well... I'd dispute the A320 as the "first FBW jet airliner". It may have been the first digital FBW airliner but Concorde preceded it with an analogue FBW system.
EGSUcrew
Wed Sep 26, 2012 10:54 am
Quoting David L (Reply 1):
I agree   Then when it wouldn't accept Concorde I couldn't find the button to skip the question lol
bueb0g
Wed Sep 26, 2012 11:10 am
Quoting bueb0g (Thread starter):
Alright, will change that question! Or should I change the answer to Concorde? That'd make it a bit more challenging...
Quoting EGSUcrew (Reply 2):
You don't have to skip it, if you put an answer that is correct for one of the questions it'll put the answer in to that Q, no matter which one you're "on"
DL_Mech
Wed Sep 26, 2012 1:21 pm
If you type in "307," it does not register. You must type in "Boeing 307." If you type in "747,'' it enters right away.
This plane is built to withstand anything... except a bad pilot.
bueb0g
Wed Sep 26, 2012 3:19 pm
Quoting DL_Mech (Reply 4):
Thought I fixed that, I'll check it again. EDIT: That's been fixed, thanks for the heads-up.
[Edited 2012-09-26 08:39:10]
Fabo
Tue Oct 02, 2012 11:27 pm
The Concorde is not worlds first supersonic airliner, Tu-144 is. By first flight, 12/68 vs. 3/69, as well as EIS, 12/75 vs. 1/76.
Also the carrier version of the Su-27 is also known as Su-27K (for Korabelniy, loosely equivalent to Naval)
And one last thing, C-47 is not "the military variant", it is merely the "US Army designation(variant, if you will)". There is the Navy R4-D (hope I got this right), which is military, and the RAF Douglas Dakota, which is military as well.
[Edited 2012-10-02 16:29:28]
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
