MaverickM11
FS9 Longhaul--too Fast? World Too Small?
Sat Sep 29, 2012 4:36 pm
I just flew DELIAD at Mach 0.82 at 36,000 and it took only 13 hours, when in reality the DELEWR/JFK nonstops take 1-2 hours longer on average. This is pretty consistent with most of the long haul flying in FS9--are the winds not strong enough? World too small? Flying too fast? I can't quite figure it out. On top of that it seems like the time change is almost always off by 1-2 hours. Noon westbound flights from the West Coast arrive in HKG 1-2 hours later on the clock, when it should really be 4-6 hours. I feel like it's all related--anyone else have the same issue?
E pur si muove -Galileo
9VSIO
RE: FS9 Longhaul--too Fast? World Too Small?
Sat Sep 29, 2012 4:53 pm
What weather settings did you use? Default or real-world?
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
wilco737
Sat Sep 29, 2012 7:10 pm
The time zones usually are off quite often. Don't know why.
For the weather check that you use real world weather and check that winds aloft are downloaded as well.
What routing do you fly? Direct GPS? You never fly direct in real life, routing is always longer if you follow the airways.
Hope that helps a bit.
wilco737
MaverickM11
Sat Sep 29, 2012 10:16 pm
Quoting 9VSIO (Reply 1):
Quoting wilco737 (Reply 2):
Active sky evolution
I use FSNavigator to create a routing, which is probably closer to Direct GPS than in real life. I figured it looked sufficiently 'circuitous' with the FSNavigator routing rather than pointing the plane straight at the destination but perhaps not!
wilco737
Sun Sep 30, 2012 8:04 am
Quoting MaverickM11 (Reply 3):
Never heard of that active sky thing. I guess it is an add on.
FSnavigator I heard it is quite good, but never used it, so no clue.
The direct GPS is for sure off at times, as you fly shortest distance, which you usually don't do in real life. And due to winds you usually fly the minimum time track and not minimum distance track - simply saves fuel (which is irrelevant in FS)...
Do you take the flight times from the airlines' website?
wilco737
9MMPQ
Thu Oct 04, 2012 7:29 pm
There's a number of variables in all of this of course.
The route FSnavigator plots for you may very well differ from the actual routes in use for the flights you are trying to mirror. If i sometimes compare my FSBuild routes to what some real life flightplans are doing they're always different.
Airways at certain times might not be available or the company might not have overflight rights for certain countries etc etc etc. Tools such as FSnavigator do not take such things into account. 1-2 hours off on what is in real life a roughly 15 hour flight then doesn't seem too bad.
I never really noticed time zones being off. I'll keep an eye on that on my next long haul
I believe in coincidences. Coincidences happen every day. But I don't trust coincidences.
nighthawk
Fri Oct 05, 2012 12:41 pm
There are many factors wh
Quoting MaverickM11 (Thread starter):
www.gcmap.com quotes that DEL-IAD at Mach 0.82 should take 13:51 minutes, and bearing in mind that this is direct GPS, then this does indeed sound like FS is slightly off. In reality it should take longer than this due to wind, airport congestion and following airways rather than direct GPS.
mdavies06
Mon Oct 15, 2012 2:59 pm
The default time zones for India and HKG in FS9 are off, so I always used to use UTC until I get them corrected using add on programs.
1 of the 2 examples you gave (West Coast US to HKG) the flight time varies by a wide range depending on wind condition. As you probabaly know LAX-HKG flights occasionally require an unscheduled fuel stop in the worst of times during the winter.
cc2314
Wed Oct 17, 2012 2:07 pm
you can get an added program to fix the time problem in fs9,cant think of the name right now.
woady
Wed Oct 17, 2012 6:13 pm
Just did a quick google, theres a prog called FS Real Time. Not used it or looked any more into it.
A300-600R, 737-300, 737-800, 757-200, 767-200/300/ER, ERJ145, ATR72
Users browsing this forum: NC1844V and 4 guests
