KAUST
Brakes/Differential Brakes Stuck On FSX?
Sun Oct 07, 2012 12:28 am
So, on my FSX system, I had a pair of rudder pedals which were (after a period of time) stuck on Differential Brakes. I recently replaced them with a new pair I bought off of CraigsList (I know, I know), however, they are stuck on brakes itself.
Any ideas? Maybe something in the software and not in the hardware, which could be easily remedied?
Also: with it I got a throttle quadrant and the prop control and mixture control do not get recognized at all. Also possible software? Or hardware issue?
KAUST
"Houston, this is Apollo 8. We are now in Lunar orbit."
Mir
RE: Brakes/Differential Brakes Stuck On FSX?
Sun Oct 07, 2012 3:43 am
I assume you've tried fiddling with the calibration settings?
-Mir
KAUST
Wed Oct 10, 2012 1:39 am
That we have. It strangely seems as if the biggest issue is that it starts out OK, yet then sticks on diff. brakes/brakes once I set and/or tap them. (Or even make a slightest movement with the rudder pedals, even ignoring the toe brakes (it would appear.)
As it happened with a previous pair (it stuck on diff. brakes, but did not start out that way), maybe something in the software? I am afraid of having to reload it, but maybe that will help in itself?
- KAUST
n797mx
Fri Oct 12, 2012 3:07 am
Do you have the CH-USB Rudder Pedals by any chance? I had a problem where the left one would get stuck on and I was able to "fix" it by just cycling the pedals back and forth and it eventually goes away.
Clear skies and strong tail winds.
KAUST
Thu Oct 18, 2012 10:24 am
Cycling the pedals did not work, however, I have found a solution. I keep full pressure at the heel of the rudder pedals and use them solely for directional control, while for braking action utilizing the brake toggle switch on the back of my yoke. So far the new improvisation has worked swimmingly!
filler
filler
KAUST
Mir
Mon Oct 22, 2012 10:14 pm
Are you using the CH Products pedals? Your problem sounds exactly like one I had with those back in the day, and the eventual solution was (IIRC) to reload the drivers and recalibrate the pedals.
-Mir
KAUST
Tue Oct 23, 2012 11:26 am
They are Saitek pedals, actually. Would that make much of a difference in your evaluation, Mir?
Obviously would be nice to have the full function, though at least my improvisation has proven to work in a pinch.
filler
filler
filler
KAUST
Fabo
Tue Oct 23, 2012 1:47 pm
Do you have paid FSUIPC? I would try calibrating brakes from within that, setting it so that the brakes only start working at about 1/3-1/2 of the pedal movement range. Maybe there is some interference or noise that is not readily seen from within FS calibration and it makes FS go bad.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
Mir
Wed Oct 24, 2012 2:19 pm
Quoting KAUST (Reply 6):
No experience with those, so I couldn't say. But taking the same steps couldn't hurt.
If you need to keep full pressure on the heels to get the brakes to turn off, that's an indication that the regular neutral position (without your feet on the pedals) is being interpreted by the electronics in the pedals as a brake application, and that really sounds like a calibration issue. One other thing you might do (if the software drivers allow) is create a small null zone, which basically means that you'll have to move the pedals farther to see any effect. The purpose of that is generally to prevent inadvertent taps of the controls to have any input, but in this case it might stop the brake signal from being sent unless you were actually pushing down on the pedals.
-Mir
Users browsing this forum: Ellinger and 1 guest
