boacvc10
HF And VHF Receiver For DX / Aviation DX
Tue Dec 11, 2012 6:21 pm
I found this radio on Buzz Aldrin's store, and it has a good price, and good specs! Has anyone any reviews of its performance?
The ETON Grundig G6 Aviator brings you coverage of all medium-wave and shortwave frequencies, as well as FM bands. Specifically, it covers three frequency ranges. The 520kHz to 30MHz frequency range grants access to the entire AM band and shortwave broadcasts with single-sideband tuning. This far-reaching frequency range puts you in touch with news and entertainment from across the world, and also allows reception of ham radio operators, maritime and shortwave aeronautical stations. The 88MHz to 108MHz band covers traditional FM radio, and the G6 Aviator passes its stereo signal through to the convenient headphone jack. Additionally, this radio also receives the 117MHz to 137MHz National Civilian Aeronautical Band, letting you monitor multiple aircraft communication frequencies.
From Grundig G6
As some of you listen to aviation transmissions as a hobby, what radio do you use? This one seems neat.
Up, up and Away!
TS-IOR
RE: HF And VHF Receiver For DX / Aviation DX
Fri Feb 15, 2013 7:56 pm
It looks performant but big in size. I have a tiny pocket size Maycom FR100 and is reliable.
macpat
Mon Feb 18, 2013 12:46 am
I have owned the Grundig G6 for a while. I bought it as a standby am/fm shortwave receiver. It works fine for am/fm but reception on the aviation band is pretty much unusable. I haven't tried shortwave because I have other options.
The G6 is a good, compact, am/fm receiver but that's about it.
If you want to listen to aircraft and/or the tower this radio won't do it, at least with any reliability at all. So, what to get?
Two things are important. Depending on where you are, I am in lower Westchester County, NY with all kinds of airports around me, as a Private Pilot I use a dedicated handheld aviation radio, in my case a Vertex Standard Pilot III. It's about $270 depending on where you buy it, but I bought it for flight use. There are no doubt quality scanners that will receive aviation transmissions just as well. You may want to consider one of those. That said, I can sit here all day and listen to the aircraft talking to JFK, LGA, EWR, etc but cannot hear the tower, approach, departure etc.
I can't hear them because even though I am about 20 miles from LGA, the little rubber duck antenna on the handheld is too low. The only way to improve this is with an outdoor antenna up high. How high? I don't know but probably something like 30 feet or more even as close as I am.
VHF aviation communications, or any VHF is line of sight. So, you can't sit in your living room and hear the tower, approach, or departure transmissions, but you can hear the airplanes because they are up high.
Do what you want but without a high outdoor antenna, or perhaps one in your attic, you will only hear the airplanes. That said, they are fun to listen to.
Get yourself first a high antenna, (without it you will only hear the airplanes, depending on where you are), then borrow someone's scanner that covers the aviation band. See if that works for you. If so, then buy one and you have the scanner for other uses. If you are a pilot or will be one, go ahead and get a Vertex or Icom aviation handheld, connect to that antenna, and enjoy yourself.
All that said, it's not as much fun as receiving with your own gear, but a great option is simply going to liveatc.net. Listen to everything almost everywhere, on your computer.
