JP Airline Fleets 2013/2014?
Thu Mar 28, 2013 3:53 am
Does anyone know when the JP Airline Fleets 2013/2014 edition will be released? Also, are there other similar sources for airline fleets, or is JP considered the best?
LH526
Crew
RE: JP Airline Fleets 2013/2014?
Fri Mar 29, 2013 11:52 am
In my eyes, JP was THE reference back in the las Millenium and early 2000s ... nowadays it's outdated the day it gets off the press, as there are other sources on the net to get accurate and up-to-date fleet data from. Having it on your ipad or schlepping it around on spotting trips can help though for a quick reference.
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
flywrite
Sat Mar 30, 2013 4:04 pm
It's due to be released in June apparently.
Tue Apr 02, 2013 12:38 am
Quoting lh526 (Reply 1):
Do you have any suggestion for good resources on the Internet for plane spotting/reg logging?
kaitak
Sat May 04, 2013 6:15 pm
Planespotters.net has up to date fleet listings and production lists; it's kept pretty up to date. I am a regular visitor to the A330/777 production lists, which are updated every week to ten days or so.
You should also check Skyliner aviation, which has a daily update; it's usually out at about 7am CET.
For UK/Irish carriers, try Jethros fleet listings.
Braniff747SP
Mon May 06, 2013 2:47 am
I use Airfleets for general fleet info. Never had a problem.
The 747 will always be the TRUE queen of the skies!
TC957
Mon Sep 09, 2013 10:02 pm
Is anyone else disappointed in the content of the JP fleet book ? It seems to be less up to date at publishing time than when it was produced in Switzerland. They have dropped aircraft names and info on those in special colour schemes, which to me seems an intergral part of seeing a particular aircraft.
nighthawk
Tue Sep 10, 2013 8:56 am
There's also www.planelogger.com which has one of the most comprehensive searchable registration database on the internet. Fleet listings will be added soon.
With planelogger you can also mark off the aircraft that you have seen.
Flying Belgian
Fri Jan 10, 2014 11:17 am
My personal interest in JP Airline fleet is that they give MTOW data for each particular frame.
Do you know any website giving MTOW data for each airplane ?
FB.
Life is great at 41.000 feet...
Jetstar315
Sun Jan 19, 2014 1:09 am
I do a lot of aircraft research as I write for a hobby, and find two of the best resources are the Air Transport Data Bank website, www.atdb.aero, and www.airlinerlist.com. If you're looking for information on Australian (and some NZ) aircraft, you just can't beat www.aussieairliners.org - it's the best!
