rahulrahul
How Do You Land In FS?
Fri Mar 29, 2013 3:53 am
I been able to wangle a "landing" a few times, but majority of them are failures.
So, I'll ask the pros. How do I land properly???
thanks,
Rahul
PS. Sorry if this has been asked before. Searched some and couldn't find much.
A300/319/320/321/332/333/343/346 B732/738/744/752/762/763/772/773 CRJ200/700/900 ERJ140/145/170/175 MD88
AustinAllison
RE: How Do You Land In FS?
Fri Mar 29, 2013 4:51 am
I would recommend watching youtube videos of landings. If you want to get technical, think about what makes an airplane fly and all the forces that are acting in favor and against it. (Physics!)
What I did was memorize what speeds work best for landing specific airplanes through trial and error.
csturdiv
Fri Mar 29, 2013 4:55 pm
It took me quite a while to learn how to land. I started off way back with FS4 and my landings were far from picture perfect! For me it is all about speed, you need to find out what the best approach speed for your aircraft is when you are flaps and gears down. The kneeboards should have the checklists that you can review for landing procedures. When you take off, pay attention to your speed when you rotated and keep that speed in mind for when you are landing. You do not want to be coming in at 250kts, unless you are trying to simulate being a Navy pilot making an approach to a carrier.
An American expat from the ORD area living and working in SYD
FlyboyOz
Tue Apr 02, 2013 1:16 am
Just keep practicing! Then you would know how to land probably!
The Spirit of AustraliAN - Longreach
flymia
Tue Apr 02, 2013 5:25 am
Try the flying lessons in FS. They are pretty good to get the basics. Do the student pilot and private pilot lessons.
zkojq
Tue Apr 02, 2013 8:50 am
The basics:
While approaching the airport, hold the aircraft's nose two degrees below the horizon and reduce the throttle. Make sure you are looking at the far end of the runway. As you cross the airport fence, raise the nose so it is level with the horizon. Once you reach the runway threshold, raise the nose to two degrees above the horizon and gently touch the aircraft down on the main landing gear and reduce the throttle to idle.
First to fly the 787-9 (ZK-NZE, NZ103, 2014-10-09)
mrcazzy
Thu Apr 18, 2013 12:02 am
I would say at the most basic level reduce power and add flaps, it will slow you down and help you descend. Play around with power settings for best results and airplane specific
Garyck
Crew
Mon Apr 22, 2013 10:00 pm
How are you getting on?
What are you trying to Landing? Heavy jets or small?
Flight sim has built in tutorials that will help you.
I spent many hour practicing visual circuits and landing at TNCM in flight sim, No ILS, your either on the beach or on the runway ha ha
Once you master it, there is a big wide world of virtual flying, I have many hours off line, but on-line real world flying is what I like the most. Cold and dark starts starts, route planning, metars, sids/stars, real world procedures.
Here's all of my online flying stats with Vatsim - part of which is nearly 500 hours with the Level D 767
http://www.vataware.com/pilot.cfm?cid=1116826
If your struggling give me a PM, i will help with all I can.
Gary
Keep your Ladders close, but your camera closer
rahulrahul
Sun Apr 28, 2013 4:58 am
hey everybody,
thanks for the tips!
I have practiced, and am now able to land with a dash-8.
For some reason though with a jet aircraft/heavy , I can never line up with the runway on final approach.
Any help on this?
Rahul
edelag
Wed May 08, 2013 9:38 pm
For starters, when flying jets, make sure you have no wind. At least do this the first few times. It is easier.
I usually land visually. If it helps you to line up for landing; Check the radio frequency for an ILS approach (Green Triangle) on the map or gps for any airport. Place that in NAV1 in the radios. Make sure the avionics is set for NAV and not for GPS.
When inside the ILS at a proper altitude, turn on the autopilot and click APP (approach) in some third party airplanes this only works to line the plane with the runway, in others it also lines the plane with the glide scope (vertical descent).
Hope this helps, either way you'll learn something new!
Edelag
It's not just the destination, it's the journey.
BA777
Sat May 11, 2013 9:03 pm
Depends a lot on your aircraft and getting the aircraft set up the way you want it at the correct point. As mentioned above, indicated airspeed is very important...too fast at certain points and you wont have enough time to slow the aircraft to satisfy a stable approach before you reach the runway.
A basic guide for speed in a jet would be to reduce 10kts per mile, eg at 9 miles be a maximum of 190, 8 miles 180 etc all the way down. As a previous poster said, the first few times use the autopilot whilst you extend the flaps on the approach and reduce the speed, wait until it's all set and then that will give you the attitude you want to continue on that constant 3 degree path to the runway.
Standard principles apply here too, Pitch + Power = Performance... Pitch + Power + Trim = Trimmed Performance. However the MSFS default aircraft are rubbish, you need something like the PMDG 737NGX in FSX and set that aircraft like the real one and you'll get nearly the same performance.
In terms of actual landing technique, the bigger the aircraft the earlier you'll need to flare. In a 737, use a principle of check (the pitch attitude by 1-2 degrees), close the thrust levers slowly (the quicker you do it the quicker the nose will drop and make a harder landing), and then hold that attitude until you touch down smoothly. Practice makes perfect!
rahulrahul
Sun May 12, 2013 12:57 am
Quoting edelag (Reply 9):
Edelag
Quoting BA777 (Reply 10):
Thanks Everybody for the advice! I will try it out.
Rahul
NAV20
Sun May 19, 2013 12:54 pm
rahulrahul, occurs to me that I did some 'tutorials' with screenshots a few years ago, which might be useful to you.
The first one shows how to land an aeroplane manually in a crosswind. Sorry that it shows a very old-fashioned aeroplane, but I have a soft spot for the Hawker Hurricane, it was the very first aeroplane that I ever saw 'in the flesh':-
http://forums.simviation.com//cgi-bi...2/YaBB.pl?num=1129643666%3bstart=0
If you click on the (red) link at the top, you'll get another tute giving some advice on using the Instrument Landing System to land a 737.
Hope they're useful..........
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
rahulrahul
Thu Jun 27, 2013 1:11 pm
Just an update. I have been practicing, and now I can land from a Dash-8 to a 777-300 and A340-300
Thanks for the tips everybody, once again!
Rahul
Piedmont727
Sat Jun 29, 2013 8:14 pm
like almost all of them say , the more you practice the better you get , ive had fs for around 2 or 3 years and only recently started getting good landings or okay landings at places like Kai Tak http://www.youtube.com/watch?v=xXmII67lris
Cadet985
Sun Jun 30, 2013 7:28 am
Quoting csturdiv (Reply 2):
Don't feel bad. I've been playing Flight Simulator since FS95, and most of the time, I screw up my landings. I'll either come in too short, or to the left/right of the runway.
Quoting FlyboyOz (Reply 3):
Seriously, that's the best way to make your landings better.
Aloha717200
Thu Aug 29, 2013 1:32 am
Finesse. And developing a bit of a memory from practice. I prefer using the keyboard numpad controls for landing as they allow me to make more fine control inputs versus a joystick.
flyingturtle
Thu Aug 29, 2013 11:08 am
One tip hasn't been mentioned yet, and it's the same trick as used on the big, real metal.
It's counter-intuitive, but as soon as you've grasped it, you won't go back to your previous technique.
Regulate airspeed by pitch. Too fast - nose up, too slow - nose down.
Regulate altitude by power. Too low - more thrust, too high - less thrust.
David
