jetblue01
Delta MD-88 FS9
Tue Aug 13, 2013 9:46 pm
anyone know any complete packs for the Delta MD-88 2007-now livery for fs9
UltimateDelta
RE: Delta MD-88 FS9
Tue Aug 13, 2013 10:17 pm
I'd suggest the HJG MD-80 model ( http://simviation.com/hjg/downloads.htm ) with their DL livery...you'd have to install it seperately, but it's not hard. Hope this helps!
Midwest Airlines- 1984-2010
jetblue01
RE: Delta MD-88 FS9
Tue Aug 13, 2013 11:47 pm
i dont know how to install textures.. how do you do it.... whenever i try to do it it says the file isnt supported
United_fan
RE: Delta MD-88 FS9
Fri Aug 16, 2013 2:08 pm
Quoting jetblue01 (Reply 2):
It is very simple . Place the new texture in your HJG MD80 folder . Copy the 'fltsim' text document of the new texture . Paste it into the text document portion of the plane (the exact term escpaes me ). It is usually at the bottom of the folder. Renumber it to follow any other textures the plane may have . They start with 'fltsim.0',then make it 'fltsim.1' and so on.
Champagne For My Real Friends,and Real Pain For My Sham Friends
jetblue01
RE: Delta MD-88 FS9
Tue Aug 20, 2013 5:58 pm
when i go to copy it .. it wont let me paste it ..how do i get it to?
jporterfi
RE: Delta MD-88 FS9
Wed Aug 21, 2013 5:11 am
Quoting jetblue01 (Reply 4):
I'm not sure if you're referring to the texture folder or the code. It should let you paste the folder as long as you have unzipped the main folder after you download it. After you paste the folder, browse to the HJG MD-80 folder, and open the Aircraft cfg file in Notepad or another plain-text editor. Then, find the code that starts with [fltsim] (see below), scroll to the last occurrence of that code, and paste the texture code which should look similar to the following (with the indicated modifications). Replace the x that should be in YOUR code (don't copy my code- it won't work) with the next # in the sequence.
**Example texture code**
[fltsim.x]
title= DELTA MD-88 - New
sim=HJG_MD88
model=
panel=
sound=
texture=*name of texture goes here; if the texture folder was named texture.dl, i would put "dl" here without quotes*
kb_checklists=Boeing737-800_check
kb_reference=Boeing737-800_ref
atc_id=
atc_airline=
atc_flight_number=
ui_manufacturer="Boeing"
ui_type="MD-88"
ui_variation="DELTA Airlines - NEW"
ui_typerole="Commercial Airliner"
ui_createdby="Microsoft Corporation"
description="One should hardly be surprised that the world's most prolific manufacturer of commercial aircraft is also the producer of the world's most popular jetliner. The 737 became the best-selling commercial jetliner worldwide when orders for it hit 1,831 in June 1987 (surpassing Boeing's own 727 as the previous champ). However, it wasn't always that ways in the first few years of production, there were so few orders that Boeing considered canceling the program. They didn't, and the airplane has more than proven itself in over three decades of service."
