laxboeingman
X-Plane 9 Default Runways
Sun Dec 29, 2013 6:30 am
Hi everybody,
I meant to ask this question a few years back, but I did not ask it correctly. My question is: How do you change the default runways in X-Plane 9. The LAX default is 07L, but I would like to change it, so the 24s or 25s are used. Has anyone else encountered a similar issue?
Thank you,
laxboeingman
The opinions I post are mine and not of any organization I am affiliated with.
CGMAI
RE: X-Plane 9 Default Runways
Thu Feb 13, 2014 10:15 am
I'm not sure you can change the default runway...when you are at LAX (or any other airport) you can select the runway of your choice under select airport. Also I highly recommend downloading this file that makes the runways that much better: http://forums.x-plane.org/index.php?app=downloads&showfile=16270
If its not built by Airbus it must not be good ;-)
Users browsing this forum: Harry99 and 2 guests
