solro
Moving into full-frame
Thu Dec 21, 2017 9:12 pm
Hello all!
After some years on DX format, I am thinking of upgrading to full frame, with a bugdet less than $2500
The options I am considering are the D610 or D750 with a 28-300 lens either the Nikon or the Tamron.
My main concern is the performance of the lenses especially in the 200-300 range, under the scope of uploading to a.net.
My other concern are if the small differences in some specs of D750 (fps, buffer, ISO) will make a noticable difference.
I will be also open to any other solution you may have in mind!
Merry Christmas!!!!!
cpd
Re: Moving into full-frame
Thu Dec 21, 2017 9:47 pm
Someone I know has the 28-300 Nikon lens and does alright with it.
Go the camera with the better ISO, that will be really helpful. I've used FX format cameras for a long time since the D700 and D3s.
JakTrax
Fri Dec 22, 2017 6:00 pm
Don't factor A.net into your decision. Both the hobby and good images are bigger than A.net. Shoot to your criteria, not A.net's.
Karl
seahawk
Sat Dec 23, 2017 5:17 pm
For aviation I would rather go D7200 with 2 good lenses before going FX with a superzoom. And while the Nikon 28-300 is decent it only makes sense to make an existing FX set-up versatile, but not as the lens to use when you switch.
solro
Sat Dec 23, 2017 10:42 pm
Thank all for your answers!
@seahawk. I totally agree with you, I already own a D7200 with 18-105 70-300. Probably one of the best DX set-ups.
But since I moved and left the camera behind to my family, I am not like getting the same thing again.
Deal was finalized with a D750 and a Nikon 28-300.
seahawk
Sun Dec 24, 2017 8:28 am
Will be a good set-up.
Gasman
Sun Dec 31, 2017 9:24 pm
Karl
This is the best advice here. If you photograph for a.net you'll end up taking a lot of bland (but very sharp, and correctly exposed) images
