usairways@clt
Photo Spots At ORD
Mon Aug 21, 2000 8:48 am
Hi,
I will be going to Chicago and wanted to get some photos at ORD. Any good locations that anyone would like to share?
BC-12D
RE: Photo Spots At ORD
Fri Sep 01, 2000 9:23 am
There is a good spot off the approach end of runway 22. It's a gravel pull-off from Higgins (I think) Road. There are a few commercial parking lots you can use for shooting arrivals on runway 9 as well on the west side of the field. From the south side of the airport, follow the perimeter road to where it passes under the approach path to runway 4, ignore the "No Parking" signs for a few minutes and you can get pretty close. Here is the view:
http://www.airliners.net/open.file?giffile=UA757.gif&id=29885
Buy a Chicago street map and bring your scanner. If you need a list of frequencies, let me know.
Good luck!
