Finnair MD-11
Digital Cameras
Sun Sep 03, 2000 3:55 pm
Hi all!!
-Do you use digital cameras???
-What camera is it and how expensive it is (approximately).
-Do you get good quality using it???????
I am going to upgrade my camera and was thinking about buying a digital camera because it is easy to get the photos to the internet and you don't have to buy the film : ) I also thought that when scanning e.g. from the negative the quality of the photo drops but when using a digital camera you don't have to scan the photo...
So if you could answer these questions, please I'd reaaly appreciate it
Thank you
Finnair MD-11
Click for large version
Photo © Lauri Huima
MD-11
FastGlass
RE: Digital Cameras
Mon Sep 04, 2000 1:02 am
The latest stock of 3+MP digital cameras are certainly impressive and affordable. However, you would be restricted by the lenses. For casual shooting dig cams are fine for "fast turnaround", but at this period in time they are not the hot tip for aviation photography. The best exception is the Nikon D1, but they cost ~$5000. I would wait awhile...
RE: Digital Cameras
Mon Sep 04, 2000 1:38 am
Hey guys!
Does anybody (if even possible) know how for convert 10X zoom to a mm value ?
Is there a formula for that?
The reason I'm asking is that I've been looking at the Sony MVCCD1000 digital camera and it has 10x optical zoom so I was wondering!
Thanks for your help
Ed
ckw
RE: Digital Cameras
Mon Sep 04, 2000 1:55 pm
Ed, you can't do it ... a 10x zoom simply indicates a range, not a focal length - you'd need to know the focal length at at least one end of the range.
As for digital cameras in general, the quality available from slide/neg scanners is still way above that from even the latest models. Not only are we looking at more "megapixels", there is also the fact that a scanner generated pixel will contain 10 or 12 bits of information whereas a digital camera contains only 8.
If you can stand the maths and theory, have a look at
http://www.users.uswest.net/~rnclark/scandetail.htm
Colin
Colin K. Work, Pixstel
RE: Digital Cameras
Tue Sep 05, 2000 12:31 am
Hey guys!
Ckw thanks for that info.
I could not get to the page you mentioned.
I got one more question regarding resolution.
Do you know how many megapix. are there in an NORMAL picture?
For example:
A picture I took with my 35mm camera using Royal Gold 100 print film developed to a 4X6 print.
Can that be compered?
I Thank You in advance for you help.
Ed
Scooter
RE: Digital Cameras
Tue Sep 05, 2000 11:02 pm
Re: the 'megapixel' equivalent of a 35mm print:
It all depends on how it's scanned. I have heard that a 2400dpi negative scan is about an 18 megapixel image. But...I can't back that statement up, so I'll say nothing more (and hope that someone can correct me if I'm wrong). Anyway, there IS a way to compute that figure, but I have no idea how to do it.
To Finnair MD-11: if you are seriously considering a digital camera, your best bets are either the Nikon CoolPix 990, or the Oly 3030 zoom. I've had a chance to tinker with both, and they produce STUNNING results. My personal favorite is the Nikon, but I'm holding out for the 4 megapixel replacement (due out next spring).
Want to see what people are doing with digital cameras? Check out http://digitalphotocontest.com/photooftheday.asp
Very inspirational stuff!
-Scott
San Diego, CA
My name is Scott, and I am addicted to writing obnoxiously-detailed trip reports.
ckw
RE: Digital Cameras
Wed Sep 06, 2000 3:43 am
This one has been debated at length on various newsgroups, and their doesn't seem to be a definitive answer. To some extent it will depend on the photo finishing process, but the consensus of opinion from people whose opinion I respect suggests that there is no more than 200DPI of resolution in a standard print. There is much more than this in the negative however, hence slide/film scanners generally will produce better results than flatbeds.
Colin
Milt
RE: Digital Cameras
Wed Sep 06, 2000 10:41 pm
In reply to the message of Ckw.
I disagree with you that the quality of a scanner is higher than that of a digital camera. See some of latest uploads which were all done with a digital SLR, e.g.:
Photo © Marco Miltenburg
You definitly need a good film and a very good scanner to even match this result. The lack of grain and the sharpness you get from a digital camera are very difficult to match with normal film or slide.
It's neither true that digital camera's produce 8 bit results. For example my Nikon D1 (and I know some Kodak's do as well) works at 12 bits internally and you can get that out of the camera when shooting in raw format. When shooting normal JPEG, you get 8-bits output, but it uses the 12-bit data for that.
The same goes for scanners by the way. The 12-bit models also give you 8-bit results as that's the standard to work with. Most consumer slide scanners aren't 12-bit either. Most are 10-bit or even 8-bit. Only the more expensive models (e.g. Nikon LS-2000, Canon, Minolta).
You are right in saying that scanners can produce larger files than most digital camera's. This important if you want to print the picture (especially if you need a large print) but is not at all important for use on the internet. I have to down-sample all my D1 images otherwise they would be to large to view.
Grtz,
Marco
Scooter
RE: Digital Cameras
Wed Sep 06, 2000 11:39 pm
Good clarification, Milt. Yeah, for the web, a 3+ megapixel digital camera will smoke nearly any consumer level scanner availiable. But for prints, film is the only way to go. I'm guessing it'll be a good five years (or more) before we'll see sub-$1000(US) digital cameras that can truly compete with film.
Anyway, regarding that Martinair MD-11 shot...WOW!!!! I've never seen any aircraft shots taken with a D1, and I must say that I'm drooling all over my keyboard right now.   Makes my digital images look as if they were shot with a .002 MP camera...
-Scott
San Diego, CA
RE: Digital Cameras
Thu Sep 07, 2000 4:08 am
WOW Milt very, very nice shot!!
Hey what kind of zoom do you get with that Nikon?
Ed
ckw
RE: Digital Cameras
Thu Sep 07, 2000 1:06 pm
In reply to Milt's comments:
What I was illustrating was, I accept, a theoretical superiority of the scanner over digital cameras. It is a simple fact that a scanner can extract more info from a slide/neg than can be captured by a digital camera. Incidently, MOST scanners are 10 bit, and even a number of consumer scanners are 12 bit capable BUT they are "crippled" by the supplied software which only uses 8 bits. 3rd party software will get around this limitation in many cases.
But theory aside, it is also true that unless the neg/slide is pin sharp and perfectly exposed, the resolution available may not be any greater than the current crop of digital cameras. And of course there is a difference between, say 400ASA and Kodachrome 25!
With regards to the need for "more pixels", it is true that 3 megapixels is more than adequate for many applications ... but 10 megapixels is real nice if you want to crop to just a portion of the image.
Personally, I imagine I will stay in the "traditional" film world for the forseeable future, partly, I admit, because I've used film and essentially the same equipment for the last 20 years and can't imagine becoming anything like as proficient in the new medium anytime soon! Also, I'm concerned about the "hidden" costs - how much memory would I need to cart around to get the equivalent of 10-20 rolls of "best" quality images?
But if anyone out there wants to prove me wrong, I'll happily accept a Nikon D1 on trial!
Colin
Gabriel
RE: Digital Cameras
Thu Sep 07, 2000 2:16 pm
Dear gulfstreambrat,
Answering your question about how for convert 10X zoom to a mm value:
The focal length is directly proportional to the ampliation of the image. So if you consider a picture took with a 50 mm lenses as an 1X scale, the same picture shoot with a 100 mm lenses would be a 2X scale.
The problem is to fit the 1x scale with a focal length.
I'll try to explain it:
1) If you want to compare the power of ampliation of your tele-lenses with binoculars, try to do this:
Place your camera verticaly, look trough the ocular a building with the left eye. Look the same building with the right eye out of the ocular at the same time. Move the zoom until the images you get from both eyes are big the same. At that point you'll get the 1x focal length in your lenses.
i.e. with my camera I get the 1x at 70mm.
So a 10x binocular would ampliate the image as a 70 x 10 = 700 mm tele-lent.
2)If you want to get the exact 1x scale in your print copies, it's more difficult because it depends on the film format you are using (35 mm, etc).
Regards.
Gabriel.
RE: Digital Cameras
Fri Sep 08, 2000 7:13 am
I have taken these three photos with my digital cam. It is a Canon Power Shot A50. It is relatively inexpensive (399.99 for the cam, 200.00 for the 64 meg card and 100.00 for the rechargeable batteries ~$700.00)
Photo © Alexander Logan
Alex
ckw
RE: Digital Cameras
Sat Sep 09, 2000 4:33 am
Alex,
Your shots look great, and there is no question that digital cams can produce more than the required quality for web or other on-screen applications. But you cannot make a fair comparison between ultimate quality based on the display of an average monitor. I think you'll find that an A4 size print on top qality equipment from a scanned quality slide/neg will still beat a print from a digital camera. Obviously a major consideration on whether to go digital or not is your intended purpose. If hard copy of A4 and larger is required, scanners still have a significant edge. Otherwise digital cameras offer some advantages.
But to put a different perspective on this discussion - a thought picked up from one of the phot mags - what if for tha last 20 years we'd been using digi -cams and then someone came up with a new system which involved inserting a cheap cartridge into the camera which allowed for the archival storage of 36 higher resolution pics?
Colin
FastGlass
RE: Digital Cameras
Sat Sep 09, 2000 7:11 am
Well stated Colin!
Eventually we will be afforded 4-6 MP dig cams (or higher?) with interchangeable lenses, at an affordable price. The current stock of dig cams are fun to play with. Even the Nikon D1 is only in the 2.7MP range. That's just not enough resolution. The 3.3MP cameras available now are weakened by their poor lenses and optical zooms.
someday, someday
na
RE: Digital Cameras
Mon Sep 11, 2000 4:44 pm
Wait 2 years and there will be Digi-SLR-cameras competitive enough to rival the "Classic" SLR, with comparable resolution and enough lenses to choose from. But the price will still be considerably higher. Not to talk about batteries...
I agree with you, FastGlass: Over all today there is no digital camera giving the high resolution of a professional (and even amateur) 35mm slide shot, even if you are going to pay 5 times more than for a upper middle class "classic" camera like the Canon EOS 50E.
So I don´t think I´m going digital over the next 24 months, at least not if comes to aviation photography.
PUnmuth@VIE
RE: Digital Cameras
Thu Sep 14, 2000 6:57 pm
All my photos are made with a digital camera. In my case it's a NIKON Coolpix 990 with a Teleconverter (*2 --> 230mm or *3 --> 345 mm). I have to say that the digicam motivated me to take photos again. I once did it with an analog NIKON SLR but i simply was too lazy to bring my films to the shop and pick the photos up there and then scan them in. Now it's all very simple and I have to say I like the results. Even if you make real photos out of the files (not by printing them but by using any kind of online Lab) the A4 results look really good. I like it digital!!!
Photo © Peter Unmuth
