Aer Lingus
Lenses For Aviation Photography
Sat Sep 09, 2000 2:27 pm
I forgot to add this to my first post but, what is the best mm lense to use for avition photography ?
AIRCANON
RE: Lenses For Aviation Photography
Sat Sep 09, 2000 4:16 pm
Hi Martin,
i believe it depends at what location/airport you intend to take pictures. So you cannot say for example a 300mm lens would do the job. If the runway and/or the aircraft is further away you might need a 400 mm lens or more. Concering my own experience, i often use a tele-lens between 200 and 300 mm. On some circumstances, when aircraft is very close, even a 80mm lens will do. Of course it is also a question of how much money you want and can afford to spend. I for myself would like to have a larger lens in the near future.
Let´s see what other photographers suggest.
Lot´s of luck picking the right lens and much success on aviation photography.
Edwin
Aer Lingus
Sat Sep 09, 2000 4:39 pm
Well if its any help its Dublin airport here in Ireland and the runway/taxiway is between 30ft in some places to 150-200ft in others
AIRCANON
Sun Sep 10, 2000 8:43 am
Hi Martin,
i have never been at Dublin Airport exept flying over it in about 11000 ft. some time ago. the best thing i can suggest is just go ahead and start shooting pictures. then you will get some experience and notice what kind of lenses you should use. a regular one for example 28-80mm and a tele-lens like a 75-300mm should do for the beginning. maybe thats even all you need. if not, nobody is preventing you of buying even larger lenses. so just give it a try.
lot´s of luck....
Edwin
Aer Lingus
Sun Sep 10, 2000 12:23 pm
That's grand Edwin, thanks for the advice
