Mudozvon
Tripod Vs Monopod
Tue Jan 16, 2001 6:19 pm
Hello!
What do you guys think about using tripods or monopods?
Is it worthy and what is the best option?
Thanks a lot,
Faerberg Leonid
cfalk
RE: Tripod Vs Monopod
Tue Jan 16, 2001 7:05 pm
A monopod should be pretty good at shooting moving targets at long zooms, to reduce blur. You can move it around pretty fast too. Tripods are only good if the subject is stationary.
IMHO
Charles
ckw
Tue Jan 16, 2001 10:05 pm
Both have their place, both require practice to gain the benefit. Monpods are perhaps more suitable for airshows and the like - though you have to learn to work with the support, not against it ... I've seen plenty of photographers who in the heat of the moment have actually lifted the monopod right off the ground trying to track an aircraft! Not providing much support there!
With tripods, you will need to spend a fair bit of money to get anything useful. Firstly it needs to be very rigid (and probably quite heavy) to provide appropriate support for a telephoto in any kind of breeze. Secondly it needs a very good head - pan/tilt or ball socket is up to you, but you need a) absolutely smooth, even movement if you ever want to pan a shot and b) very good tension adjustment - too many heads are difficult to adjust ... they're either too loose or too tight with just micrometers between the 2 settings.
How do I know this? From spending too much money on "bargain" tripods which ultimately let me down! I've now got an expensive tripod, with an even more expensive head and it does the job it was intended to do just fine - but even this is fairly useless for subjects in flight.
Colin
Colin K. Work, Pixstel
thomasphoto60
Wed Jan 17, 2001 1:30 am
I personally use both. All of my 'action' shots, approach were taken with a tripod. I mainly use a monopod at sporting events where tripods are discourged by officials or would be more of a hinderence to my photography.
Tripods like lenses come in a variety of quality ranges so it is very important you choose carefully there are a lot of cheap and flimsy tripods out there. Myself, I use a Gitzo tripod and a Bogen Monopod both with ball heads.
Thomas
"Show me the Braniffs"
AIRCANON
Wed Jan 17, 2001 4:16 am
A very interesting question.
Very simular to the one i was asking myself for some time. I made the experience that a tripod is very useful at many times. Not only for stationary objects but also for moving aircraft. For night photos a tripod is a must.
For example these two i made using a tripod.
Click for large version
Photo © Edwin Olinowetz
I do intend to buy a monopod sooner or later. But do you have experience using a monopad while standing on a ladder? Does this work? On some spotting places you just have to use a ladder like here
and taking pictures on it with a telelens is sometimes quite tricky.
So please let me know what you think about it and what experiences you have.
Edwin
