b757300
RE: What Scanner Would You Buy?
Wed Jul 25, 2001 12:42 pm
Anyone?
"There is no victory at bargain basement prices."
jwenting
Wed Jul 25, 2001 3:54 pm
I've more or less decided on a Minolta Scan Dual II USB.
From all the ones you listed, it's the only one within my budget.
I'd love a Nikon Coolscan IV or 4000, but those are simply too expensive. Might be able to afford a IV in half a year, but I need a scanner now as the old cheapo I got as an interim died yesterday. (prices here are quite a bit steeper than in the US, the Coolscan IV would cost me over $1000, the Minolta Dual II runs at about $600 here).
I wish I were flying
ebos
Wed Jul 25, 2001 4:39 pm
I have a Minolta Scan Dual II USB and it's doing a great job. The USB scanner is easy to plug in and is rather fast. The software for image correction (brightness, contrast, gamma...) is easy to use. Most of the shots are corrected automatically. I bought it for §480.
eBOS
An-225 stalker: 1 x LUX, 1 x EIN, 1 x DXB, 2 x SHJ, 3 x CGN
cfalk
Wed Jul 25, 2001 4:59 pm
Whatever you get, don't get one with a SCSI interface. I had a Coolscan III with that, and boy, was it slow. My new one has Firewire, and the data transfer seems at least 5 or 10 times faster. I don't know if USB is as fast - I've never tried it.
Charles
ckw
Wed Jul 25, 2001 5:25 pm
In terms of speeds, it runs parallel, USB, SCSI, Firewire - but that's only part of the story - the speed of your disk will also have a bearing on how fast the data can transfer, and your processor - and especially your memory - will determine how long the scan processes takes, paticularly if you use dust/scratch removal algorithms.
What should you buy - well ultimately it comes down to what you want to use it for. If you only want to produce output for screen you can get away with a much lower spec than if you want to produce large prints.
Colin
Colin K. Work, Pixstel
AndyEastMids
Wed Jul 25, 2001 6:42 pm
I have no complaints so far about the Minolta Dual Scan II USB, although I'll admit that I prefer using VueScan than the supplied driver software. I've had it for around 5 months and every one of my shots here were scanned using it.
My prime concerns when buying it were (a) price - reasonable and (b) ease of installation as I didn't want to faff about disassembling the computer to install a SCSI card - USB sorted that.
WOuld I buy the same again? I have no way of knowing whether the more expensive scanners are worth the extra, but I'm happy with the results I'm getting.
Andy
ckw
Wed Jul 25, 2001 9:37 pm
More expensive scanners ARE worth the extra ... but only if you're gonna use that higher spec. If you want to produce A3 or larger prints, then you really can benefit from 4000 dpi. But otherwise forget it.
Colin
b757300
Whenever I buy stuff like a scanner/printer it is always USB. As for my computer, it should probably be able to handle anything. It’s a 933MHz PIII with 512MB RAM.
AndyEastMids
Wed Jul 25, 2001 9:51 pm
Hey, B757300... That's a fairly serious computer for someone who's been saying that they can't afford a film scanner!!! Big grin You could have probably stuck with a P3 450 +128mb or something like that and bought a film scanner as well!  Big grin
Colin, yes, I'm sure the more expensive film scanners offer more capabilities or facilities and these are of value to some, but I'm using my scanner only for web stuff so the 2820dpi of the Minolta does fine. Besides, when I bought the film scanner I really wasn't sure how much I was going to use it and didn't want to spend huge amounts on something that might just end up gathering dust. Five months later, I know the answer to that one - it gets used quite a bit!
Andy
b757300
Wed Jul 25, 2001 9:55 pm
The computer belongs to my parents, not me. I just get to use it for things that need better computing power then my personal one can provide. I'm just a poor college student. My personal computer is a 133MHz Pentium I but it does have 128Mb or RAM! Nuts
BO__einG
Wed Jul 25, 2001 11:36 pm
that low but that fast!
usb is the way to go. 4200 for iv coolscan here in my place.. wow.
Follow @kimbo_snaps on Instagram or bokimon- on Flickr to see more pics of me and my travels.
Sonic99
Thu Jul 26, 2001 12:17 am
A bit off topic but here's just a word to folks out there that belive that more RAM will do the trick - it won't (for the most part).
Unless your system's running WinNT, 2000, Unix (various flavours), or OS/2 then anything over 128 is generally pointless anyways. Win 95, 98 and ME doesn't make use of all the RAM (above 128MB), although some applications that run in all those environments/OS's do use up the RAM independently of the OS (Photoshop, for instance). However, since most progs are OS/environment dependent, then by the virtue of the OS's limitations data processing (not the type associated with using Word or WordPerfect) will be affected accordingly. One method of increasing this is having a faster processor.
Cfalk,
I'm surprised you didn't get quick results with your SCSI scanner. I suppose it depends on the card you have. Most scanners require a simple SCSI interface, but by that token the transfer speeds are limited to a mere 10-20 MB/s transfer rate. (When considering the transfer of raw data - that's slow!!). A higher-end SCSI card will offer up to 80-160MB/s transfer rates.
Sonic99
ckw
Thu Jul 26, 2001 1:51 am
Sonic99 - not strictly true ... what you get are diminishing returns for memory over 128mb - some improvement, but not much. However, this applies to running benchmarks under Windows, not real world situations. Any graphics/scanning software I'm aware of can take advantage of as much memory as you can throw at it, with significant improvements in performance.
Andy - I'm in full agreement with you - the point I wanted to make was not to waste money on a super high res scanner UNLESS you're sure you're gonna need 100mb+ files!
Colin
jwenting
Thu Jul 26, 2001 3:40 am
I've found a nice price for the Dual II. Money being transferred from my savings account as we speak, hope to have it operational in a week or two.
mirage
Thu Jul 26, 2001 5:09 am
Just to see what kind of difference you may get from a flatbed scanner to a film scanner, this first photo was scanned with a HP 5100C flatbed scanner:
Click for large version
Photo © Luis Rosa
the last one I upload using this scanner.
This was scanned with a recent HP S20, negative scanning:
Photo © Luis Rosa
Luis
