AA 737-800
Gimme' My Chances
Thu Jul 26, 2001 12:28 pm
Not wanting to waste my time or the screeners, I was hoping I could get the professional opinion of the user of this forum about my photographs. If you would please look at a few of my pictures and tell me what you think of them and what I could do to improve. Thanks in advance.
http://www.robotgroup.org/lubbock/airliner/VN80.jpg
http://www.robotgroup.org/lubbock/airliner/USX1900D.jpg
http://www.robotgroup.org/lubbock/airliner/737.jpg
http://www.robotgroup.org/lubbock/airliner/CO739-2.jpg
http://www.robotgroup.org/lubbock/airliner/SW737-2.jpg
http://www.robotgroup.org/lubbock/airliner/Falcon900.jpg
http://www.robotgroup.org/lubbock/airliner/AF340.jpg
http://www.robotgroup.org/lubbock/airliner/CO739.jpg
http://www.robotgroup.org/lubbock/airliner/CO735.jpg
http://www.robotgroup.org/lubbock/airliner/Connie and KC.jpg
http://www.robotgroup.org/lubbock/airliner/KLM747.jpg
Civil engineering isn't about making things perfect...just better.
jwenting
RE: Gimme' My Chances
Thu Jul 26, 2001 3:13 pm
DNS lookup failure. Seems the domain is unreacheable...
I wish I were flying
Bruce
Thu Jul 26, 2001 3:50 pm
The "Connie" pic only shows part of the plane. I doubt this will make it on.
Southwest 737-2: also the same. part of the plane, plus the contrast on the bottom of the fuselage is too dark. Actually the whole shot looks a little dark. Try to brighten it up.
The one called "737.jpg" is framed up nice, but just a tad blurry. Just to play around I downloaded this to my desktop and opened my Photoshop 6.0. I used one pass of "sharpen edges", and unsharp mask with these settings: 115%, 1.0 radius, threshold 5.0 and it looks much better. Try it.
The one called CO735.jpg looks sharp enough, but try to crop out some of the dead space on the left of the wing. All the other planes are a little distracting. The only problem I can see might be the darkness of the shadow under the plane. I got that on my pics and they were rejected.
"co739.jpg" you're cutting off the planes nose gear! Try to shoot a little lower to include it all. Plus it looks a little bright.
"af340.jpg" - try using a sharpen edges & unsharp mask like I said above and submit that pic.
Let me guess - this is at IAH right?? I would know! I stood in that same EXACT spot (gate 9 international terminal) and shot a AF777!!!
Click for large version
Photo © Bruce Leibowitz
Thu Jul 26, 2001 9:10 pm
General comment: All these files are too small, i.e. they have already been compressed, which will increase grain.
VN80.jpg : Camera is not level. Rotate the picture about 2 degrees to the right. Apply a little bit of sharpening, but be careful not to do too much - there is grain starting to show up, especially around the engine. That grain might actually be scanner noise - does your scanner support multiple passes? That might help. Beware of taking pictures when the sky is hazy-white like it is here. It really makes the easthetics of the picture suffer. The toughest part to fix will be the fuzziness around the edges of the verticle stabilizer. You might consider rescanning at a very large size, and downsizing it using an anti-alias algorithm, if your software has it, before sharpening up. Finaly, a little color saturation would help.
USX1900D.jpg : This one is pretty blury, but already quite grainy. You will definately need a better scan - a file which is both grainy and blury like this is beyond repair I'm afraid, as reducing the blur will make the grain even worse.
737.jpg : Similar problem as USX1900D.jpg above, though not as bad. A new scan would also be in order, I think. Use masks to allow you to sharpen up the plane without affecting the sky.
CO739-2.jpg : Needs to be rotated 2 or 3 degrees to the right. Needs a new uncompressed scan, as it is already quite grainy. Lighting here really washed out the dynamics of the colors - a little saturation would be in order.
SW737-2.jpg : Too much compression, grainy and very dark. Definately needs a new scan. I don't mind having part of the plane cut off - the angle is interesting, but the fact that you cannot see anything in the shadows ruins it. I managed to improve it a lot by really pushing the gamma hard - the bottom of the plane, landing gear etc became very clear without overpowering the bright areas, unfortunately the scan quality could not handle the gamma increase without a lot of horizontal and vericle banding.
Falcon900.jpg : Needs a lot of sharpening, and needs to be a bit brighter. Try to mask the sky so that you don't sharpen it as well.
AF340.jpg : Not bad, although damaged by already being too compressed. On a new scan, make it a little bit sharper (not the sky), and a little color stauration as well.
CO739.jpg : Nosegear got cut off. Recrop to include it, and some careful sharpening, and it has a chance (although I would try with a new, uncompressed scan.)
CO735.jpg : Exactly the same as CO739.jpg, although the nosewheel is now visible  Smile. In addition, I would brop out the left side of the picture to center more on the 737.
Connie and KC.jpg : A little more sharpening and saturation could be useful. Level off the ground as well
The lighting was not very good for this kind of shot, but you had a good idea.
KLM747.jpg : Probably too far gone to be saved. Motion blur on everything, including the aircraft.
I hope that helps.
S2
Users browsing this forum: aircountry and 1 guest
