jwenting
Blurry?
Thu Aug 09, 2001 9:36 pm
This one (and 2 others like it) got rejected for being "very blurry". Any thoughts?
http://www.photo.net/photodb/photo?photo_id=316223&size=lg
I wish I were flying
cfalk
RE: Blurry?
Thu Aug 09, 2001 9:44 pm
J.T.,
That pictures does look pretty blurry. How does the original look - better? Did you scan a film/slide or a print? What kind of film did you use?
Charles
cfalk
RE: Blurry?
Thu Aug 09, 2001 9:46 pm
Oops, I didn't scroll down far enough. Sensia 100 on an F80 should give you a much better result than this. As I said, is the original well in-focus?
Charles
Jan Mogren
RE: Blurry?
Thu Aug 09, 2001 9:47 pm
Yes it is blurry.
/JM
AeroPresentation - Airline DVD's filmed in High Definition
jwenting
RE: Blurry?
Thu Aug 09, 2001 9:58 pm
Weird. On my screen there is no bad blur at all. Everything is sharp when checking with a loup (as well as the 30MB scanfile).
Granite
RE: Blurry?
Thu Aug 09, 2001 10:15 pm
If it does not look blurry to you, you may need to get new glasses.
Very blurry to my eyes.
Gary Watt
Aberdeen, Scotland
george
RE: Blurry?
Thu Aug 09, 2001 11:54 pm
Hi,
If you can't read the name of the plane on the nose or the titles "The Flying Dutchman" from that distance then for sure it is blurry.
Kind Regards, George Polfliet
jwenting
RE: Blurry?
Fri Aug 10, 2001 3:44 am
rescanned with adjusted focus. A lot sharper on the big file (30+MB), still readable on the uploaded one (600+KB)
RE: Blurry?
Fri Aug 10, 2001 4:00 am
I think you should avoid shooting through glass. It introduces refelctions and scatters the light producing soft images.
jwenting
RE: Blurry?
Fri Aug 10, 2001 4:04 am
This was not taken through glass... Unless you mean the lens on the camera  Smile
RE: Blurry?
Fri Aug 10, 2001 4:33 am
J.T.,
I just saw it. MUCH better. But there is a chance Johan might think it a little dark, especially in the shadows (could be fixed with gamma). We'll see.
Good luck.
S2
jwenting
RE: Blurry?
Fri Aug 10, 2001 5:17 am
Thanks. It was really that dark on the day. Heavy clouds and occasional showers. The scan may even be a bit brighter than the slide as it is  Smile/happy/getting dizzy
Sonic99
RE: Blurry?
Fri Aug 10, 2001 5:45 am
Could you post a link to the uploaded image? I'd like to sneek a peek at the re-worked photo.
Sonic99
jwenting
RE: Blurry?
Fri Aug 10, 2001 6:15 am
same as before, I replaced it. photo.net does sometimes cause some lossy compression so small details may be slightly distorted.
jwenting
RE: Blurry?
Fri Aug 10, 2001 10:20 pm
Guess Johan didn't like it. "poor quality" indeed... Not every day is a sunny day with perfect light...
Users browsing this forum: Bing [Bot], henkita217, Kaphias and 2 guests
