H. Simpson
Should I Resize The Photo?
Thu Aug 16, 2001 10:13 am
Hello world,
my scanner is a HP 3200C, I scan the photo with 800dpi and the file is about a 20-something mb. I use Canon Photo Gold editor to sharpen the photo and resize to 1024*680.
The question is will the picture become sharper after I compress the photo(because I "squeeze" 800dpi)?
I still getting blurry image after I scan with 800dpi, work on it using sharpen ,brightness and compress into 1024*680 size. Why? Confused
Thannnnnnks!
Mike Smile/happy/getting dizzy
RE: Should I Resize The Photo?
Thu Aug 16, 2001 11:37 am
What is the "native" DPI of your scanner without inerpolation? I can scan at 3200 DPI if I want, but there's no point, because the scanner just invents the in-between pixels (its native resolution is 600dpi, which is typical, although there are some 1200dpi flatbed scanners now). Find out what the native res. of the scanner is and scan at that.
The picture will not be sharper just because it is smaller, but any problems (blurry, out of focus, etc.) will show up less because they aren't as big!
You will always need to apply some sharpening to the final 1024 x 680 sized image after you have resized it in order to ensure it's sharp. The trick is to apply enough to get the image sharp, without introducing "jaggies"
S4
H. Simpson
Fri Aug 17, 2001 4:05 am
I had no idea what's the native resolution is, i think it's 600dpi, but in the software, it said the best resolution is 150dpi.
But thanks anyway, S4
Sonic99
Fri Aug 17, 2001 10:07 am
Native resolution = optical resolution (normally advertised as such). Most scanners can achieve even higher resolutions than the optical capability and this is referred to as "interpolating".
Scanning at higher than optical resolution is no solution at all since this will only cause dissolution....  Laugh out loud
i.e. if you have a 600dpi scanner, then scan your photos at that resolution and try to achieve the highest pixel output you can get. Then shrink the photo to a maximum of 1024 pixels (length). Never enlarge from the output otherwise the image will be filled with "garbage" pixels.
Hope this helps.
Stephan
H. Simpson
Sat Aug 18, 2001 5:24 am
Ok, thanks for advice Stephen.
