xenon
Still Foto's Or Action Foto's
Thu Sep 06, 2001 2:45 am
Hi,
Is it normal that when I shoot "moving/landing"
planes the quality of my pictures are less the
when I shoot a "still" picture?
I uses a digital C2100.
Any advice is welcome.
Daniel
AirTeamImages -ATI-
jwenting
RE: Still Foto's Or Action Foto's
Thu Sep 06, 2001 4:17 am
When shooting moving objects, you need to freeze the movement. This means you need a higher shutterspeed (shorter exposure).
Using the same exposure as with static objects will incur motion blur on the moving object. This can be used to effect, but unless you do so deliberately it is highly annoying.
I wish I were flying
Craigy
Thu Sep 06, 2001 4:25 am
Daniel,
Yes, this is because fast moving aircraft require faster shutter speeds, which in turn require better light. This applies to all cameras.
Pan smoothly, squeeze the shutter gently and resist the urge to stop panning as you take the shot. I think your camera has the 38-380mm IS lens. That helps.
I've looked at your shots in the database - they are very good.
Craig.
Craigy
Thu Sep 06, 2001 4:26 am
I guess we were typing at the same time, JW
jwenting
Thu Sep 06, 2001 5:02 am
guess so. Happens all the time.
