Aer Lingus
Best Film For Bad Weather Photography
Sun Oct 21, 2001 9:22 pm
Can anyone recommend a good slide film for low winter light/bad weather shooting please ?
Not too expensive if at all possible
Jan Mogren
RE: Best Film For Bad Weather Photography
Sun Oct 21, 2001 9:34 pm
Provia 100F.
If you are desperate, push it one stop.
/JM
AeroPresentation - Airline DVD's filmed in High Definition
cfalk
Sun Oct 21, 2001 9:37 pm
Jan's suggestion is probably the best. If you really, REALLY need to go up to 400 speed, Provia 400F is a class above any other alternative, but is rather expensive.
Charles
Aer Lingus
Sun Oct 21, 2001 9:38 pm
Just out of curiosity how does Sensia 100 fair in these conditions ?
One other thing how do you push a film one two stops ?
Jan Mogren
Sun Oct 21, 2001 9:45 pm
To push one stop you set the film speed to 200 instead of 100, and you *make sure* to tell the lab to process +1 stop.
Be careful with metering the light under those conditions as that is probably the most difficult.
Don't let the light of the sky fool you.
/JM
Aer Lingus
Sun Oct 21, 2001 9:48 pm
Ok, great thanks Jan. I'll have to experiment a bit first with that.
IIRC didn't you say that you pushed this Provia 100F shot 1 stop ?
Click for large version
Photo © Jan Mogren
cfalk
Sun Oct 21, 2001 9:49 pm
On most cameras, you can override the automatic ASA rating of the film (done by the DX code on the side of the canister). For 100 ASA, for example, pushing one stop means you manually set the ASA to 200. Pushing 2 stops would make you set it at 400.
After you've shot your film, tell the developer to develop it at +1 or +2 stops, as they must use different development times accordingly. This also means that if you want to push a film, you have to do the same for the entire film, not just a few frames.
Pushing any film one stop can usually be done with a minimum of loss of quality. 2 stops may be stretching it, depending on the film. Provia pushes quite well. I haven't tried Sensia.
Charles
Jan Mogren
Sun Oct 21, 2001 9:54 pm
That shot is +1 stop, yes.
/JM
da Fwog
Sun Oct 21, 2001 11:47 pm
I have pushed Sensia by 2 stops on an occasion when I was desperate for something faster, and the results were acceptable, so there should be no great problem with pushing it by a stop.
Bear in mind that almost all labs will charge you extra in order to push process the film for you. And you MUST tell them, and mark CLEARLY on the can "PUSH +1" or "+1 STOP" or else you'll get back a film that's all precisely underexposed by a stop.
Aer Lingus
Mon Oct 22, 2001 1:29 am
Jan, Charles and Chris - Thanks I'll give both films a try
Staffan
Mon Oct 22, 2001 5:06 am
I shot of a roll of K64 and most of my photos turned out very dark, so I've tried to take one photo at 64 ASA, and one at 50 ASA of the same subject at the same time. Will the 50 ASA shot turn out very underexposed if the film is developed normally?
Staffan
Jan Mogren
Mon Oct 22, 2001 5:59 am
It will be brighter, not darker.
/JM
Staffan
Mon Oct 22, 2001 6:12 am
Oops, I meant overexposed, not underexposed...  Smile
Does this usually work?
Staffan
Jan Mogren
Mon Oct 22, 2001 7:26 am
It sure works.
It will be 1/3 of a stop brighter than the ones exposed for 64.
/JM
Staffan
Mon Oct 22, 2001 7:28 am
Thanks, I'm looking forward to seeing the results!
Staffan
jwenting
Mon Oct 22, 2001 4:31 pm
I wouldn't call Provia cheap. Over here it costs abour $12 a roll, compared to $3 or less for Sensia...
I wish I were flying
