LH738
Lens: Canon Powershot Pro 90-IS
Sat Dec 01, 2001 2:45 pm
I intend to buy a Canon Powershot Pro 90-IS. The lens is 37-370mm.
370mm is great - but only 37mm. Are there any adapters available to go below 37mm?
jasonm
RE: Lens: Canon Powershot Pro 90-IS
Sat Dec 01, 2001 4:21 pm
The wide converter lens WC-DC58 converts the focal length by about 0.8x, and the 58mm Close-up lens 500D enables shooting as close as 13.4in (34cm) at the telephoto end.
Jason.
EGGD
Sat Dec 01, 2001 8:16 pm
Enjoy it!
I think there is about 3 wide angle lenses that will fit (although you might need some sort of lens adapter for the thread).
Dan
planedoctor
Sun Dec 02, 2001 5:56 am
You will probably get the best results using the Canon WC-DC58 which gives an effective focal length of approx 30.4mm at the wide end, which is quite substantial in my opinion. I have not used it, however. Going with a 3rd party lens opens up the possibity of other problems. I expect that it will give a bit of distortion on the wide end, but that is one of the trade-offs with having the Pro90's 10x zoom. I think you will really enjoy the Pro90. Good luck!
-Ken
hkg_clk
Mon Dec 03, 2001 11:22 pm
I've got a Pro90, and although I am reasonably satisfied, there are some things which are quite irritating. The lag time between shots can be quite long, and under very bright conditions, purple fringing can be a bit of a problem, especially at max zoom. The wide angle is not very wide, but you can get a converter.
See my homepage for a comprehensive guide to spotting and photography at HKG
EGGD
Tue Dec 04, 2001 12:48 am
Yup, i don't like the Electronic viewfinder and both that and the LCD display stay blank for a long time between taking the picture and storing it etc.
