hisham
Resolution Problems
Sun Jan 20, 2002 4:19 am
Hi,
I'm having problems of getting high resolution scans. Even with a 9000 DPI, they're still of much lower resolution than the prints. I tried to play with other parameters (Sharpening, contrast..). Nothing worked.
Any advise about increasing resolution?
Hisham.
ghost77
RE: Resolution Problems
Sun Jan 20, 2002 4:23 am
Hisham,
Can you write the link to the picture(s) are you refering to.. so we can see and tell you maybe what´s wrong.. or help you out with the problem.
Ricardo  Smile APM
Ricardo Morales - flyAPM - ¡No es que maneje rapido, solo estoy volando lento!
cfalk
Sun Jan 20, 2002 4:28 am
9000 dpi ?!?!?!?!
4000 dpi is typically the top end for slide scanners, and something like 1200 dpi for flatbeds.
Charles
aps
Sun Jan 20, 2002 5:06 am
The last image he scanned was 2585mb  Nuts
seriously though there are scanners with that capability , but not very often used..
hisham
Sun Jan 20, 2002 8:31 am
Yes the scanner has a 9600 DPI option. But the scan is a low res anyway. The scanner is a Umax Astra 1200S.
I can't upload the pic. But if you're willing to take a look at it, I can email it to you in a 116K jpg format. Send me an email to the address in my profile so I can write back.
Thank you.
Hisham.
Jan Mogren
Sun Jan 20, 2002 8:34 am
That is interpolated, right?
/JM
AeroPresentation - Airline DVD's filmed in High Definition
hisham
Sun Jan 20, 2002 8:39 am
What's interpolated?
Hisham.
Jan Mogren
Sun Jan 20, 2002 8:44 am
That is when the software "makes up" pixels just to make the scan bigger. That would make your scan look "not so good".
/JM
hisham
Sun Jan 20, 2002 9:12 am
Yeah, I see what you're saying. The problem is that even lower PDI's are nor working (200 or 800 DPI). So it could be that the scanner isn't good enough. How do you know the real resolution of a scanner?
Hisham.
LOT767-300ER
Sun Jan 20, 2002 9:17 am
I have a Astra Net 5420 thats only 1200dpi max,
BTW the Astra 1200S has 600 optical dpi, interpolated dont count heheh
Jan Mogren
Sun Jan 20, 2002 9:19 am
It should say Optical resolution somewhere in the manual.
/JM
cfalk
Sun Jan 20, 2002 9:40 am
Using any resolution on prints higher than 600 dpi is overkill - as prints themselves are only printed at 300-400dpi anyway.
Charles
hisham
Sun Jan 20, 2002 9:58 am
If the Astra 1200 has an optical resolution of 600 dpi and the print has a res of 400 dpi, then why is the res of the scan much worse than the print?
Thanks for the replies.
Hisham.
cfalk
Sun Jan 20, 2002 10:15 am
Could it be that your scanner has a focus problem?
Charles
