hkg_clk
RE: Advice Please On These Rejected Photos
Thu Feb 14, 2002 12:13 pm
Anyone? Just a brief/quick comment would still be much appreciated!
See my homepage for a comprehensive guide to spotting and photography at HKG
ILS
Thu Feb 14, 2002 1:03 pm
The NW Cargo is by far the best. The others are a little iffy and lack that true sharpness.
Shawn Patrick
Thu Feb 14, 2002 1:26 pm
In my opinon, in most of them, the aircraft does quite fill the better portion of the picture, which is why they were probably rejected. Also, bad angles.
How do you find your rejected photos like you did?
hkg_clk
Thu Feb 14, 2002 1:32 pm
Shawn, do you mean that I should crop out more of the non-plane parts of the photos?
As for angles, do you mean that I should try to upload side-on views only?
To find your rejected photos, just copy the link I posted above, and just change the file name to the file name of your photo.
fuairliner
Thu Feb 14, 2002 4:35 pm
Hkg_clk,
Here is why I think your photos were rejected:
  1. too blurry, sky shows sign of grain
  2. too blurry, the tail section looks strange (lines are ditched)
  3. too blurry, not level (the plane looks bended)
  4. a bit blurry at the rear section, there seems to be no colours on the picture (almost black & white)
Hope this helps,
 Smile/happy/getting dizzy FUAirliner
(Frank Unterspann)
Frank Unterspann - Hamburg, Germany
hkgspotter1
Fri Feb 15, 2002 6:37 pm
They look great.
Lets go back and look at the photos in the database, I'm sure there are thousands that are worse then these.
Fri Feb 15, 2002 7:02 pm
I like the Singapore 773  Smile
vafi88
Sat Feb 16, 2002 12:22 pm
they look to be a tiny bit overexposed, but toherwise they're pretty good.
I'd like to elect a president that has a Higher IQ than a retarted ant.
da Fwog
Sat Feb 16, 2002 6:58 pm
1,2,3: not quite as sharp as they should be, but there's not much in it. Perhaps heat haze is playing a part in this lack of sharpness? Without exception they are leaning to the right. The colours also seem a little "muddy"
As to the Northwest 747 - I like the shot, the framing is great, but the colours seem to be very dull indeed. Try increasing the contrast and colour saturation on this shot to see if you can improve it that way.
hkg_clk
Sat Feb 16, 2002 8:17 pm
Thanks for all your comments. I have tried all kinds of settings but cannot get any sharper shots. It was a little hazy, but not too bad that day (Hong Kong is always hazy!). Do you think maybe there's something wrong with my camera? Or could it be due to the fact that I was shooting with max zoom (i.e. 10x at 370mm)? (I use Canon's Pro90, settings were exposure compensation -1/3, saturation high, sharpness and contrast normal).
