hkgspotter1
Full Frame?
Mon Mar 04, 2002 12:33 am
OK, I've noticed a number of people using these words in the remarks section, along with the fact they are using a *****mm lens !!. Thing is non of the pictures are full frame on the plane, so what is full frame ??
Staffan
RE: Full Frame?
Mon Mar 04, 2002 12:43 am
Probably mean that they haven't cropped the photo after scanning it.
Staffan
TomH
RE: Full Frame?
Mon Mar 04, 2002 1:10 am
A full frame shot is one where the aircraft takes up about 85-90% of the significant axis of the film image before croppping. That's the way I have always understood it. Are there differening opinions?
wietse
RE: Full Frame?
Mon Mar 04, 2002 2:20 am
Full frame means to me that a shot is not cropped. It means the shot is just as the slide or negative was. Also, It means that no zooming in on the slide has taken place.
Wietse@AMS
Wietse de Graaf
skymaster
RE: Full Frame?
Mon Mar 04, 2002 4:19 am
Wietse@AMS
You are right. Full frame is showing the entire slide or negative regardles how small or big the motif is.
Click for large version
Photo © Erik Frikke
Erik
Glenn
RE: Full Frame?
Mon Mar 04, 2002 5:10 am
This shot is 100% full frame no cropping was used at all
Photo © Glenn Alderton
Carlos Borda
RE: Full Frame?
Mon Mar 04, 2002 5:59 am
Below are some examples of what avid slide collectors would regard as "full frame." It basically entails the aircraft covering the entire whole width of the slide frame... from nose to tail without clipping either one. And it doent have to be a ramp 50mm shots either, it can also pertain to 200mm zoom shots.
Photo © Carlos Borda
Photo © Michael F. McLaughlin
Photo © Joe Pries
And here are some "full frame" action shots... basically same rules as the ground shots but in action.
Photo © Joe Pries
So basically the idea in "full frame" is to cover up the entire slide area from end to end.
~Carlos
mirage
RE: Full Frame?
Mon Mar 04, 2002 6:19 am
No Carlos, this is a full frame:
Photo © Luis Rosa
Luis
P.S. being ironic
Schiphol
RE: Full Frame?
Mon Mar 04, 2002 6:37 am
I think this one is full frame too!
http://www.airliners.net/addphotos/big/NCA_747_JA8167_takeoff.jpg
Bye
SPL
Carlos Borda
RE: Full Frame?
Mon Mar 04, 2002 7:10 am
Luis, it looks like every other boring sunny 50mm side on shot I've seen here over the years....  Big grin
Here's another boring one...
~Los
Mirage writes:
Luis
P.S. being ironic<
hkgspotter1
RE: Full Frame?
Mon Mar 04, 2002 9:45 am
Yes, thats what I mean. So the pics Im talking about ARE NOT FULL FRAME !!
TomH
Glenn
Mon Mar 04, 2002 9:53 am
Your shot makes me wonder if there isn't such a thing as "over full frame."
Staffan
RE: Full Frame?
Mon Mar 04, 2002 9:59 am
Well, full frame can mean two things, if I hold an aircraft photo in my hand and the pictured aircraft fills up the whole photo, then it is full frame. But, if I have a scan of any other slide I would comment "full frame" to indicate that this is what the actual original looks like, and that it hasn't been cropped. In this case it doesn't matter if the subject covers the whole size of the photo or not.
Just my 2 cents..
Staffan
Joge
RE: Full Frame?
Mon Mar 04, 2002 6:02 pm
Full frame:
Photo © Jorgos Tsambikakis
I would have rotated that to get the horizon straight, but as after that I must have cropped it, there would be missing a piece from the wing and the nose would be just visible. I should have panned the camera before taking that photo...  Big grin
-Joge
Bula!
Users browsing this forum: bluedevil and 1 guest
