jr
Spotting Directions For MIA And FLL
Fri Mar 08, 2002 1:09 am
I will be in Miami this weekend (mar 9,10). Could someone give me the directions to the best current spotting locations at both MIA and FLL?
Your help will be greatly appreciated.
Josh
I've flown on 9V-SPK.
scottysair
RE: Spotting Directions For MIA And FLL
Fri Mar 08, 2002 8:16 am
Hi Josh,
This is Scott. I'm live in Hollywood and photography at the Ft. Lauderdale/Hollywood International Airport. And you can go take on Ravenwood Rd on near Griffin Rd by I-95 and you can turn on right on Ravenwood Rd to overbridge near 7-11 store and then you turn left again and you see it with viewing area on the right side, okay. You can do that as for direction how you were get there at my FLL airport. Thanks!!
Scott W.
jr
Fri Mar 08, 2002 11:02 am
Thanks Scott, I'll be sure to check it out.
DB777
Fri Mar 08, 2002 2:41 pm
MIA: the approved spotting holes are just east of the Customs Cargo Clearance Center which is on NW 25th Street and just north of the two FAA control towers. Don't park in the Customs lot or you will meet some real a-holes. This location is on the west side of MIA and you can reach NW 25th Street from NW 72nd Avenue (Milam Dairy Road), the Palmetto Expressway (State Road 826), or from the north on Perimeter Road which goes around the northwest corner of the airport just south of NW 36th Street. If you get a decent map you should be able to see what I'm talking about.
FLL: take the Griffin Road exit off of I-95, go west to the first light (can't remember the name of the road - Ravenswood?), make a right (north) until the next light. There are signs saying "General Aviation" or something like that. Make a right (east), go up and over the bridge over I-95 and you'll come to a 4-way stop at the bottom. Make a left (north) and go to the next stop sign. Make a left (west) and follow the road up to I95 fenceline and then it curves right (north) and the viewpark will be on your right. You'll be just south of the approach end of 9-left.
Don Boyd
Photographing aircraft since the Earth was flat and on Airliners.net since #338
jr
Fri Mar 08, 2002 11:51 pm
Thanks for the detailed directions Don. Much appreciated.
scottysair
Sat Mar 09, 2002 9:21 am
Yes, that is Ravenwood Rd on the near Griffin Rd. You can do that as for direction get there at viewing area. Thanks again!
Users browsing this forum: spompert and 1 guest
