digby
Addphotos Page Crashing IE.
Mon Apr 22, 2002 12:39 pm
Hi all,
I have been uploading photos for quite some time now, but only in the last couple of days, has the 'addphotos' page on the site been causing troubles. I click on the toggle switch which says "add photos" (as I've always done) and it goes to that page, but doesn't load correctly. When I leave it to finish loading it stops before completely loading and crashes my browser.
I'm using IE V5.0. and I have asked a fellow photographer whom also uploads to Airliners and he is experiencing the same problem.
Has anyone else had this problem???
Will a browser update fix the problem, or is there a different solution?
David Morrell
Friends don't let friends shoot Nikon!
737heavy
RE: Addphotos Page Crashing IE.
Tue Apr 23, 2002 5:11 am
Hi, I've only ever seen this problem on a few other web sites when my browser used to crash. I used to use IE5.0 then I upgraded to IE5.5. I haven't had any problems since installing 6 but I suppose there is always a first time. It might be worth installing the upgrade. It should ruin your computer.
digby
Tue Apr 23, 2002 10:38 am
Thanks for the info. I might try doing the upgrade and see where it gets me. Hopefully a re installation is the key!
David.M.
digby
Tue Apr 23, 2002 1:06 pm
Problem solved!!!
Firewall protection was too great.
David.M.
737heavy
Wed Apr 24, 2002 1:52 am
Firewall? Hmmm I didn't realise it used a different port. Still if it's working it's working!
