Can You Help Identify This MUC Airport?
Tue May 14, 2002 3:56 am
Hi all
This photographer has asked for help in identifying the airport at the top of this overhead photo of Munich-Franz-Josef Strauss:
Photo © Kevin Tate
Not exactly my neck of the woods, so can any one of you help?
BTW, on another topic, a change to our corrections scripts has meant a faster processing of corrections sent in by the photograph's owner. At the moment there are zero owner-sourced corrections in the queue  Smile and there should be a normal turnaround of 24 hrs at most for this type of correction in future.
Andrew (Southflite)
Corrections Editor
Skymonster
RE: Can You Help Identify This MUC Airport?
Tue May 14, 2002 4:36 am
Andrew (and Kevin!!!),
I've just fired up my copy of Proplan (a flight planning program) and the other airfield near Munich FJS, is Erding AFB - 6.7 nm on a true track of 106 deg.
FJS has dual 08-26 runways, and Erding has a single 08-26. Nothing else remotely fits.
Andy
There are old pilots and there are bold pilots, but there are no old bold pilots
MUC_Spotter
Tue May 14, 2002 5:35 pm
that's right. It is indeed the Erding Army airfield.
Greeting from Munich!
MUC_Spotter
Wed May 15, 2002 3:30 am
Thanks for the info, Andy, and for confirming it, MUC_Spotter  Big thumbs up
lufthansi
Sun May 19, 2002 6:25 pm
That's right the airport is called Erding like the famous beer from this region. The code is ETSE. These are the notes from the FS2000 were you'll find the airport too:
Erding AB (ETSE)
ATIS-Frequenz: ***
Breitengrad: N48* 19.34'
Längengrad: E11* 56.92'
Höhe über Meer: +1514
Start-/Lande- Ober- bahn Länge fläche ILS-ID ILS-Freq. ILS-Steuerkurs
8 8258 Beton *** *** ***
26 8258 Beton *** *** ***
Life starts at take-off!
