apjung
Sony CyberShot DSC-P71 And Post 9/11 Planespotting
Mon Aug 12, 2002 3:56 pm
I am a first time contributor and I knew this would be rejected since I forgot to enhance it.
http://airliners.net/procphotos/rejphoto.main?filename=msy-deltamd88_01.jpg
I am also determined to get more B767 pictures at MSY Airport on A.net and even this enhanced picture got rejected.
http://airliners.net/procphotos/rejphoto.main?filename=MSY-Delta767-332_08_enhanced.jpg
I was questioned by the Kenner Police Dept. and I asked permission while they were checking my ID to take final pictures when the (link above) 767-300 I was waiting for was coming by.
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe=UTF-8&selm=IXT39.338351%24DB.9824038%40news1.east.cox.net
My graphics software program is MGI Photosuite III that came with the Visioneer One Touch 8100 scanner. All of these photos are from Sony CyberShot DSC-P71 (3.2 megapixel, 3x optical 2x digital zoom) digital camera. Is this adequate in aviation photography that can produce acceptable A.net photos? I have it set at the maximum 2048x1536 resolution and sometimes at the maximum 6x combined optical/digital zoom. What other settings are recommended?
http://www.sonystyle.com/home/item.jsp?hierc=9682x9128x9045&catid=&itemid=32123
Here's another enhanced image I haven't submitted yet and it has been cropped to the recommended 1600x1200 resolution.
http://public.fotki.com/apjung/planespotting/msy/boeing_767/boeing_767-200_series/msydelta767232_02.html
Also, here's one I really want to submit but I need to crop and enhance.
http://public.fotki.com/apjung/planespotting/msy/boeing_767/boeing_767-300_series/msydelta767332_03.html
Any assistance is appreciated. Thanks.
Andy P. Jung
Andy P. Jung
brianhames
RE: Sony CyberShot DSC-P71 And Post 9/11 Planespotting
Mon Aug 12, 2002 6:34 pm
Hello,
I have the Sony DSC-F707 which is sorta similar to your camera. Anyway, I think your camera could produce photos good enough for a.net, what I do is, take photos on the largest resolution, to make sure you get the maximum megapixels your camera can offer, also I have the ISO set on Auto, same with White Balance, and also I set my sharpness to +3 I think. Also I use the camera in manual mode and I try to keep a fast shutter speed and adjust the apature accordingly to keep a good light. And thats all you can really do on the camera.
As for editing on the computer, I use Adobe Photoshop and there are three things I always do to the picture, first I resize the photo to 1024x748, that makes the photos look much better, then I use the "Auto levels" feature to get a better color balance, then I use the sharpening filter to sharpen the photo a little bit. And by then the photo looks very nice.
If you try resizing that Delta 767 photo where its taxing toward you to 1024x748, it looks very nice, and if you use the Auto Levels feature, if your running photoshop that is.
Well I hope that all made sense.
Brian
Mon Aug 12, 2002 7:43 pm
I've still got my DSC-P1 (an early version and similar to yours) and it is very adequate.
I've no problems here using that DC for a.net pictures.
1# Keep the settings at maximum; 2048x1536 resolution.
2# Don't use digital zoom, switch it off. It is just interpolation, the worst kind.
3# Keep sharpen to default '0'. PC Unsharp Mask Filter is more contollable than a basic built in camera feature.
4# Suggest you level, crop and resize to 1000 pixels maximum width, no need to go to 1024px width or even greater every time..
5# Sharpen the shot after resizing with the Unsharp Mask tool. Get to know how to use it. There are plenty of other threads in this forum about USM.
Hope this helps..
Gerry/EDI
apjung
Sat Aug 17, 2002 5:54 pm
Hey, thank you so much for the helpful advice. My first photo has been accepted! There's just one little problem. A.net finally just changed the MSY name of New Orleans International Airport to Louis Armstrong International Airport but my picture hasn't been moved there.
I submitted the photo a few days ago when A.net had it as New Orleans International Airport in the pull down menu.
http://www.airliners.net/open.file/263436/M/
Andy P. Jung
Andy P. Jung
Users browsing this forum: Masataka1430 and 1 guest
