PH-BFA
Spotting @ Brussels
Wed Sep 11, 2002 12:19 am
Could someone give me some information about spotting @ Brussels? For example how is the view from the restaurant Wingtips? Can you also see(and photograph) the DHL freighters from there? And how much mm's do you need for different types of airplanes? Furthermore does anybody have some good tips where to spot at Brussels accept the restaurant and how is the accessebility of those spots(from the terminal)?
Many thanks in advance!
PH-BFA
apuneger
RE: Spotting @ Brussels
Wed Sep 11, 2002 2:07 am
If you're looking for good information about spotting at BRU airport, check out http://users.telenet.be/PowerCorruptionLies/BRU.htm.
Concerning your examples: view from the WingTips restaurant used to be pretty good, but since they built the new Pier A, the view you had of RWY 07L/25R has mostly been obstructed. But you can still see aircraft taxiing on the ramp between Pier B and Pier A. I'm not sure if you get a good view of DHL freighters from the WingTips restaurant but I wouldn't be surprised if this is the case (DHL is located to the left of WingTips restaurant and since most freighters are located somewhat in front of the DHL buildings, it's possible to get a good view of them, especially when they taxi (not sure of this, so don't shoot me).
I can't tell you all the different focal lengths you would need; this depends on the distance between you and the aircraft. What I mean is if, e.g., a 737 parks just next to the WingTips, you will probably need a wide angle, but if a 737 is taxiing at the other end of Pier B, you will need a good tele. This is also the case if an aircraft takes off from RWY 25R for example: a 50mm won't do the job, not even on a 747.
Concerning the other spotting locations, it can be quite difficult to access them, especially if you can only rely on public transport. However, I was told that one of the most famous spotting locations is accessible by train: you have to take the train from the airport and try to make it to 'Kortenberg' station. Also, it is possible that you can access some good locations by bus (there are lots of buses that depart from the airport terminal), but I don't know their exact routings. You can always try to find some addition information on http://www.delijn.be or send an e-mail to antwerp@delijn.be or vlbrab@delijn.be.
Hope this helps!
Ivan
Ivan Coninx - Brussels Aviation Photography
PH-BFA
Wed Sep 11, 2002 2:29 am
Thanks for the info Ivan! Very much appreciated
PH-BFA
gust
Wed Sep 11, 2002 3:17 am
When you come to Brussels ?
Wim
744rules
Wed Sep 11, 2002 4:14 am
On sunday majority of the a300 dhl fleet is parked in front of their building. Also mind that the taxiway between a-pier and b-pier is closed due to works. Due to the same works part of the dhl platform is closed as well (might be open by sunday, but don't know how long the works will take).
PH-BFA
Wed Sep 11, 2002 6:03 am
'When you come to Brussels '
coming Thursday
PH-BFA
gust
Wed Sep 11, 2002 11:06 am
Hello,
Maybe I can you pick up by the terminal and drive with you to the landing runway in use, 25L or 02 (easterly wind).
Wim
Sabena 690
Wed Sep 11, 2002 5:01 pm
Hi PH-BFA,
Check also this link out:
http://www.airliners.net/discussions/aviation_photography/read.main/39758/
Enjoy your stay in Brussels!
Frederic
PH-BFA
Wed Sep 11, 2002 5:14 pm
Gust,
Love that idea! Would be wonderful! Thank for you very much for the offer.
PH-BFA
Users browsing this forum: miamivice and 1 guest
