BA777
How To Acheve Good Cockpit Shots
Sun Oct 06, 2002 3:14 am
Hi Guys,
I might have the oppourtunity soon to visit a place where there are lots of planes parked that i can go on (no it's not an airport  Wink/being sarcastic a maint. base actually:P)
Chances are, that ill be using my Minolta SLR with my 50mm own, goes to about f1.7 ish i think.
I will hopefully also be using a tripod, so is it best to let the shutter do itself and choose the widest possible aperture?
I'll be using either Reala or Superia 200 - Any comments or tips at all?
BA777
res
RE: How To Acheve Good Cockpit Shots
Sun Oct 06, 2002 3:17 am
The time I took shots in a cockpit, my first shot was too fast and I didnt catch all the CRT screens (due to frame rates). Almost like taking a shot at a television - you get those bars in the photo. Good thing I have a digicam so i could see my mistake and take another one.
This is the only realy problem i had...maybe its just me.
-Tim
FLY NAVY
BA777
Sun Oct 06, 2002 4:31 am
Res,
I would usually use a digicam, but my Dads got it, and he's on a boat in the middle of the Atlantic atm, and might not be back in time  Wink/being sarcastic http://www.challengetransat.com btw.
How do you avoid the "bars"
BA777
Shawn Patrick
Sun Oct 06, 2002 4:51 am
The thing that makes cockpit shots difficult is the fact that there usually isn't much light available.
What you should do is use the lowest F-stop you can (f/1.8 or whatever) so that enough light will get in to the camera. Use 1/60 shutter speed or faster, otherwise you'll get motion blur. ISO 200 film should be good enough to get a good cockpit shot.
Take a look at one of mine:
Photo © Shawn Damphousse
ISO 100, f/2.2, 1/30
Good luck!
Shawn
BA777
Sun Oct 06, 2002 5:04 am
Shawn,
Ill have a play with the ISOs, the lowest f is actually f1.7  Big thumbs up
Is that digital, it sure looks like it  Wink/being sarcastic
BA777
Shawn Patrick
Sun Oct 06, 2002 5:28 am
Yep, that's my Sony F707 digital cam. I love it!
BA777
Sun Oct 06, 2002 5:30 am
Thought so, hopefully ill have the flexability of a digi for mine, only ISO200 though, but that'll be fine.
BA777
luchtzak
Sun Oct 06, 2002 5:39 am
Hi,
maybe another tip: set your camere to auto-flashmode when taking pics e.g. whilst landing.
Here are 2 examples!
Photo © Bart Noëth
Photo © Bart Noëth
kind regards,
luchtzak
http://www.luchtzak.be
Swim - bike - run - finish! And a flight attendant ;-)
Shawn Patrick
Sun Oct 06, 2002 5:48 am
I always hate using the in-camera flash because the light is just too harsh. If you can, put a piece of tissue or something over the flash. It will diffuse the light and make it a little softer.
EGGD
Sun Oct 06, 2002 6:05 am
Yup you can either sync-flash or just take a slow exposure and play steady hand game or get a tripod..
BA777
Sun Oct 06, 2002 6:36 am
Yeah, ill def. be using a tripod, no doubt about it.
BA777
CX Flyboy
Sun Oct 06, 2002 9:48 am
If I was flying I wouldn't want someone behind me with a flash taking photos on short finals!!
luchtzak
Sun Oct 06, 2002 5:16 pm
Yes,
forgot to say I set my autoflash to low.
If you ask, they don't mind.
greetings,
luchtzak
ckw
Sun Oct 06, 2002 5:28 pm
1 - be wary of using the lens wide open .. depth of field will be very small - too much may be out of focus - go for a longer shutter speed instead.
2 - you could well be working with a contrast range beyond the ability of film/sensor to capture correctly (bright outside the windows, dark inside) - be careful your exposure settings are not over influenced by the light outside. If in doubt, bracket your exposures.
3 - Flash - problematic these days as it tends to reflect off the CRT screens which doesn't look pretty. If you have the capability, bouncing the light off the cockpit roof can help
Colin
Colin K. Work, Pixstel
Shawn Patrick
Sun Oct 06, 2002 11:55 pm
Also note that the shorter the focal length, the larger the DOF. You could probably get away with f/1.7 if you have, say a 17mm or 28mm lens.
Shawn
BA777
Mon Oct 07, 2002 2:07 am
It's a 50mm lens, so.....
BA777
boeingholiday
Mon Oct 07, 2002 3:37 am
Yes, light may be our biggest problem. Here's one shot without a tripod.
Photo © Markus Wechselberger
I asked the pilot and he said: "Oh yes, please!"  Big thumbs up Depends on the crew.
n949wp
Mon Oct 07, 2002 3:49 am
Given the relatively tight confines of a cockpit, a 50mm will not be wide enough if you intend on shots like this:
Photo © Alexander Jonsson
In general, I find a 17-35 zoom much more useful for cockpit shots. With the 50, you may be limited to shooting clusters of instruments only.
'949
