airplanetire
Will A Correct Size Filter Work With Any Lens?
Tue Nov 26, 2002 10:58 am
I was wondering if a correct sized filter will work with any lens of that size. Will it? I would like to try a polarizer filter and wanted to see if it would work with my camera and a lens that I will be getting in the near future. The lens is a Canon 75-300mm f4.0-5.6 II/III USM lens and the polarizer filter in question is a Quantaray 58mm circular polarizer filter. The filter size for the lens is 58mm. Thank you very much!
JeffM
RE: Will A Correct Size Filter Work With Any Lens?
Tue Nov 26, 2002 11:18 am
Yes, it will! As long as you can screw it on, or mount it in a holder, it will work. If the lens is smaller then the filter, you can usually buy step down rings that will make up the difference.
With a circular polarizer, make your filter adjustments AFTER focusing, as some lenses will rotate the end of the lens, throwing off the "dialed in" setting of the filter.
Jeff
